Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 04-25-2011, 09:41 AM   #1
Shiloh's Avatar
1968 30' Sovereign
Montgomery , Texas
Mounting a new toilet?
I have a 68 sovereign. The toilet leaks water from the box on the side that the flush pedal comes out of. I believe it is the original one, and I have just about decided that a new one would save headaches down the road, but here is the problem:
All the new toilets I have seen mount with 2 bolts and mine has 4 bolts sticking out of the floor. Is that necessary to keep a seal with movement? Could I just grind 2 of them off? Is there a way to get at them from underneath? Should I just find a toilet that uses 4 bolts? What do I do?! Thanks in advance!
Shiloh is offline   Reply With Quote
Old 04-25-2011, 10:15 AM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Shiloh, our 67 has a metal flange in the floor, and the bolts slip into it from the top: There should be no need to work from the bottom or to saw anything off -- unless they're just corroded together somehow. The bolts are generally made of brass.
Just a slight thing with ours. Last time I had the toilet off, I realized that part of the reason it was sooo hard to reinstall was the shortness of the bolts. So I located extra-long toilet bolts at the hardware store, and they certainly helped.
Oh, and be sure to use the rubber-style RV toilet gasket. It's flexible, allowing some down-the-road movement while maintaining the seal.
Lynn
ACI Big Red Number 21043
Old 04-25-2011, 10:48 AM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Knowing you had a water leak helps inthat eubanks corrosion is more than a blind guess, the two bolt ones have a slot for the head of the bolt, wouldn't take much to make them feel unmoveable. I was lucky as they were rust free and once loosened the nuts moved freely, no room to put a large wrench.
Old 04-26-2011, 09:22 AM   #4
Shiloh's Avatar
1968 30' Sovereign
Montgomery , Texas
So, just to clarify, if I remove the extra 2 bolts and install a toilet that only uses 2 bolts, (with a rubber rv gasket) it will be fine and not have any problems?
Old 04-26-2011, 09:50 AM   #5
eubank's Avatar
Airstream - Other
Should be fine. Ours has only two bolts, too. If that's the design of the commode, then it is what it is.
Lynn
Old 04-26-2011, 02:11 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The new toilet will mount with just 2 bolts. I recently install an Aqua V and it has 1 bolt on each side. It would be best if you have a solid floor to mount the metal (or plastic) flange. There are key hole shaped slots that the toilet flange bolts slide in to. Most toilet will require the slots to be at 9 and 3 o'clock.
Old 04-29-2011, 06:23 AM   #7
Shiloh's Avatar
1968 30' Sovereign
Montgomery , Texas
Thank yall so much! I feel better now that I'm not just guessing and hoping for the best
Leaking toilet Bmtt Sinks, Showers & Toilets 6 05-10-2011 12:09 AM
Toilet mounting flange Green68 Sinks, Showers & Toilets 7 03-21-2011 08:21 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
1968 22' Safari vinyl toilet cover wanted! dawnhugh70 Interior Restoration Forum 4 03-08-2011 05:21 AM
mounting toilet flange on black tank 386kustoms Sinks, Showers & Toilets 3 03-04-2011 07:52 AM
