Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 07-10-2006, 05:14 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Veggie diesel users?
Are you using veggie diesel in your rig? If so how is it set up?
I am looking into it utilizing the extra tank in my F250 7.3 PSD.
Finding a lot of info, just trying to decide what to do from here.
Could it be as easy as flipping the switch in the truck to the back tank, once I get a filter and pre-heater set up? In my climate do I even need a pre-heater.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-10-2006, 06:42 PM   #2
Images: 59
Alan,
Are you talking about biodiesel (methyl esters of vegetable oil), or the straight soybean oil burner.
The methyl ester has a wax point of 32F, quite a bit higher than diesel, which starts to crystallize at 5F.
Fuel conditioners that work on diesel also work on biodiesel, but not as well.
Old 07-10-2006, 07:08 PM   #3
BeBop's Avatar
2000 27' Safari
Berkeley , California
I have been using B100 Biodiesel in my truck since I bought it. No negative aspects of use have presented themselves thus far. Biodiesel can be splash blended with petrodiesel, hence when on the road you can use either as they make themselves available enroute. When in could weather, I will run either a bio/petro blend or straight petro. Where I live, I would say most of the time I'm B100.
Pros: Engine runs quieter, less noxious emissions, higher lubricity, nice smell
Cons: Higher price, limited availability, slightly lower mpg than petro
Since my truck is not my daily driver, I don't mind the added expense. I pay $3.70/gallon currently, professionaly produced. My daily driver is a Toyota Prius.
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline   Reply With Quote
Old 07-10-2006, 07:23 PM   #4
ZoominC6's Avatar
2004 30' Classic Slideout
2021 33FB Classic
Colleyville , TX
Alan,
I experimented with Bio in my last Duramax came up with basically the same findings as BeBop. If it makes you feel good (green) then by all means, do it.
I'm not at all certain what the production costs of Bio are but have a feeling that they are higher than petro.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 07-10-2006, 07:26 PM   #5
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Alan, I know a guy here in Atlanta that picks up the used cooking oil for free from a local Mexican restaurant, strains it and so on, and pours it right into the tank. He says he uses diesel to start & warm up the oil, then switches over. Claims he buys about one tank of diesel a month. The cooking oil is free to him and saves the restaurant owner the expense of have to dispose of it.
I swear this story is true! He says not to spread this around too much, or his source will dry up (or start charging him for it).
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Jim & Susan is offline   Reply With Quote
Old 07-10-2006, 08:33 PM   #6
JimGolden's Avatar
1977 31' Excella 500
Berkeley Springs , West Virginia
There are several kits on the market for this. Yes, you need to start and stop on "real" diesel. You can "run" on french fry grease. You basically set up two tanks with a switch valve up by the injector pump. You start and warm up the engine on diesel fuel. You then switch it and drive on french fry grease. Before you shut down, you want to purge the lines and so you switch back to diesel for the last five minutes or so.
You need to strain the grease really well before you try to burn it.
The biggest deal is the viscosity. Generally you need to plumb some coolant lines through the french fry grease tank. It's not such a big deal in summer, but in cold winters, you need to heat the grease up a lot before you try driving on it. It's not a simple two tank affair: you really need to take the viscosity into account and run some lines from the radiator through the grease tank. The heat thins it out so that the injector pump can then use it without having a heart attack.
But, if you do it right, you can run your diesel just fine on it. Rudolf Diesel himself ran his first engines on vegetable oil.
Go for it, and let us know how you make out!
- Jim
JimGolden is offline   Reply With Quote
Old 07-10-2006, 08:38 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
that's what I am talking about, veggie oil form my local Chinese restaurant. Hope to get this going, I will let you all know how it works out. I did see good info at www.greasecar.com
AIR #005
retired!
Old 07-10-2006, 10:10 PM   #8
silverback's Avatar
2006 28' Safari SE
Colorado Springs , Colorado
We've been blending in commercially produced B100 (or B20) in the 04 Duramax and our 06 VW Beetle TDI. It's actually a little cheaper here in AZ. Only positive results so far.
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 07-11-2006, 06:06 AM   #9
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you find those products locally for sale? I don't see them here, not even Ethanol is available for gassers here yet.
By the way those are bio-diesel, not 'veggie' I assume.
AIR #005
retired!
Old 07-11-2006, 07:27 AM   #10
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Alan,
Are you thinking about a two tank SVO system? I too have been checking out greasecar.com after my brother in law turned me onto it....love the profile about a 40 Class A that converted: http://www.greasecar.com/profile.cfm?profileID=52
It would be interesting to talk to owners as sourcing the SVO seems to be something easier said than done (unless you know some restaurant owners).
Steven Webster
AIR 1760
swebster is offline   Reply With Quote
Old 07-11-2006, 09:03 AM   #11
silverback's Avatar
2006 28' Safari SE
Alan,
Yes. I'm referring to bio-diesel. Ethanol (E80 I think) and bio-diesel flavors are available commercially in AZ.
-Ken
4CU Charter Member
Old 07-11-2006, 10:35 AM   #12
Ledbehind
2018 16' Sport
Great Falls , Virginia
bio diesel
Alan,
I've been burning b-5 with no problem - I've heard that the "seals" whatever they are get brittle with contact with veg.oil - probably another oil industry myth. I'd run at least b-20 If I could find it closer to where I live. What I have found out is that my Liberty doesn't know the difference btw "highway" diesel and biodiesel
Ya want fries with that??
Henry
henrydahm is offline   Reply With Quote
Old 07-11-2006, 02:32 PM   #13
Sioux Falls , South Dakota
Interesting thread, especially since we're planning on buying a diesel pickup.
Does anyone know if the new diesel engines due out in 2007 will run on biodiesel? (These are the diesel engines that HAVE to use "ultra" low sulfur diesel fuel, or USLD fuel.)
Linda
P.S.: By the way, here are a couple of websites that give biodiesel fuel locations around the country:
http://afdcmap.nrel.gov/locator/LocatePane.asp
http://www.biodiesel.org/buyingbiodi...s/default.shtm
elh3946 is offline   Reply With Quote
Old 07-11-2006, 04:52 PM   #14
silverback's Avatar
2006 28' Safari SE
no sulfur in B100
Linda,
Bio-diesel is the original ULSD. I saw a report yesterday that the new (07) Dodge/Chrysler diesels will support B20.
-Ken
4CU Charter Member
Old 07-11-2006, 07:55 PM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I have heard with the right filtering I can run straight veggie recycled diesel, with no mods using my extra tank. Would like to be sure before I actually try it though, thinking pre-heater is not needed here in hot GA.
AIR #005
retired!
Old 07-14-2006, 10:12 PM   #16
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I followed a Volkswagen TDI early this evening with a big decal on the rear window stating that his car had been modified to run on veggie diesel. Decal also had a website, but I have fogotten it. Kind of implies that at least some modification may be required.
John W. Irwin
WBCCI #9632
Old 07-15-2006, 02:30 AM   #17
volvophile's Avatar
colorado springs , Colorado
Images: 14
try thedieselstop.com
Check out http://www.thedieselstop.com/ , its Ford Diesel-centric and a lot of discussions on biodiesel.
I run B20 in my 97 Ford since I can get it localy through Acord petrolium.
Ive been to chicken to try fryer grease in a $5k motor.
Overall its about 10cents a gallon cheaper, and theres a noticable improvement in HP.
We get our diesels dynoed every year as part of the emmisions test
theres about a 10 HP improvement from when I started running the B20.
Emissions where lower to.
volvophile is offline   Reply With Quote
Old 07-15-2006, 05:59 AM   #18
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I am running biodiesel in my truck, also. I blend it myself, so concentration varies, I try and keep it between 5-20%. I would not run straight SVO or WVO in an HPCRD.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-15-2006, 06:14 AM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am still checking. Seems you can run the veggie oil with minor mods, filtering, etc. Will post what I find out if I get this going. Right now too many projects, too little time.
AIR #005
retired!
Old 07-30-2006, 07:14 AM   #20
RobertC's Avatar
1970 21' Globetrotter
Pickens , South Carolina
I've been running "WVO" (waste vegtable oil) in my old 1971 Mercedes Benz 220D for awhile now. I work in a nursing home and get the used oil from the oil dumpster there for free. I filter it though an old blue jean leg with the end tied in a knot, hung over a barrel. I then blend about 20% petrol with it to lower the viscosity, and just dump it in the tank. I always add it to a tank that has about half petro-diesel already in it. I've heard that some people run just this mixture but I havn't tried that yet, I prolly want. The engine actually runs smoother with the WVO than without. I'm not saving alot, but some costs.
Skip Callaham
RobertC is offline   Reply With Quote
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
1981 Airstream Excella Diesel dienst1 Airstream Motorhome Forums 6 10-02-2003 04:45 PM
Isuzu Turbo Diesel stuart1 Mechanics Corner - Engines, Transmission & More... 0 10-28-2002 01:23 PM
Isuzu Diesel islandvu3@cox.net Mechanics Corner - Engines, Transmission & More... 7 10-28-2002 11:53 AM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
