Just bought an E-Joe Epic SE...what a hoot!!👍
Motor: 500W Rated with 700W Peak Rear Brushless Geared Hub Motor
Battery: 48V 10.4Ah LG 18650-Cells Lithium-Ion
Range: up to 30 miles (depending on terrains and rider’s weight)
Recharging Time: about 4 hours (at low battery)
LCD Display: ON/OFF Power, Speedometer, Tripmeter, Battery Indicator, Pedal Assist Level
Pedal Assist System: 5 Level Pedal Assist, Thumb Throttle Control
Frame: 6061 Aluminum Alloy Frame Foldable Design
Tires: 20” x 1.75” Kenda Puncture-Resistant Tire
Seat: Giddy-up memory foam
Brakes: Front/Rear: TEKTRO 180 mm Rotor Disc Brakes
Gearing: 7-speed Shimano Tourney TX-55
Accessories: Front/Rear Fenders, Rear Rack, Magnet Clip, Front/Rear Lights
Weight (with battery):50 lbs.
Dimensions when unfolded: 65 x 27 x 46 inches
Dimensions when folded: 35 x 24 x 17 inches
Load Capacity: 300 lbs.
Colors: Frosty White, Black Matte, Sky Blue Tangerine
Will be taking it on our trip to the W. Coast in Sept.
