08-25-2012, 01:03 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Proven Windshield sealant
Some 11 years ago I used the best SIKA Windshield glazing/sealant available to seal the windshield of my 79 Moho. I had a few issues that require a thick application in 1 area. The SIKA sealant held up for 11 years and still is going strong. I went back to the same Glass company and ask for their best Polyurethane product from SIKA available now to reseal the windshield of my 345. They sold me SIKA Tack Moveit and I applied it today
After carefully removing the old sealant, I used my airhose to blow any dust and dirt out from under the gasket. Then I cleaned the glass and the rubber with Lacquer thinner and applied the masking tape to create a appr 3/8" wide strip, half rubber and half glass. The sealant needs to be applied rather fast and is even harder to use than Vulkem. It can be smoothed out with paint thinner for appr 5 to 10 minutes and then should be left alone. The tape should be removed immediately after application.
I recommend using gloves during application, since hardly anything works to get it off your hands.
This makes for a nice clean look that will last a long time.
AIR #13
08-25-2012, 01:55 PM
Richmond
, Kentucky
Peter,
Great tip! I've been thinking it wouldn't be a bad idea to put some sort of sealant on the windows of our 310 and Argosy.
Wouldn't you know, one more thing to add to the list
Thanks!
1975 24' Argosy Motor Home
08-29-2012, 12:39 AM
nanaimo
, British Columbia
Rubber and Aluminum
Do you do anything with the aluminium skin to rubber joint?
08-29-2012, 05:55 AM
Airstream Driver
1994 30' Excella
Austin
My aluminium/rubber seal is tight. But when I purchased the tube of Sika, the technician told me to "roughen up" the aluminum slightly after taping it off as I did with the glass/rubber. This is not really needed , but will improve the bond. There are small pads available that contain glass particles to prep certain surfaces. A professional auto glass shop has those pads, if you ask for them.
AIR #13
09-25-2012, 07:31 PM
Richmond
, Kentucky
Peter,
I've searched everywhere online and can not find any place that sells the Sika Tact MoveIt product.
Any suggestions?
Thanks!
09-25-2012, 08:46 PM
Airstream Driver
1994 30' Excella
Austin
Originally Posted by bkahler
Peter,
Any suggestions?
Thanks!
Check with these folks, they claim to carry the entire sika line
http://www.jamestowndistributors.com/
800-497-0010
I purchased mine from the local Glass company, but it was not an item they had on display. I had to ask about it very specifically.
Good luck!
AIR #13
09-26-2012, 05:03 AM
Richmond
, Kentucky
800-497-0010
Good luck!
Thanks Peter. I'll try calling them today.
How many tubes did you use for your windshields? I have two motorhomes to do so I want to make sure I get the appropriate amount.
09-26-2012, 06:11 AM
Airstream Driver
1994 30' Excella
Austin
Brad, depending on the thickness of your bead and if you do the glass only, 1 tube for both if you do them the same day. Once you crack the seal, it will get polluted at the tip even if you try to stick something in it (fast dry). It is very stiff, so if you can set tube in the sun for a couple of hours it will help.
AIR #13
09-26-2012, 07:57 AM
Richmond
, Kentucky
So in other words I better buy some extra tubes cause I'm likely going to need them
Since we're heading into winter it sounds like I need to wait for a nice sunny day, have the front of the motorhomes face south and do it in the early afternoon.
Thanks again!
09-26-2012, 08:53 AM
Richmond
, Kentucky
Well, I tried James Town Distributors and they referred me to another company who said they don't carry it and suggested I google Sika automotive, so I did. It's weird that the Sika website describes the product but I can't find anyone that seems to sell it.
Richmond doesn't have a lot of Automotive glass businesses so till now I hadn't bothered to check them out. I think I'll stop at the two that show up in the phone book and see what they have to offer.
08-16-2013, 02:13 PM
Richmond
, Kentucky
Just finished sealing my Argosy windshields with the stuff Peter mentions above. I can vouch for the fact that it is fast drying
I do have a couple of recommendations that might make things a little easier for the next person. One of the mistakes I made was to tape off the entire windshield at one time. The problem with this approach is since it is such a fast drying product you can't remove the tape easily since it overlaps with the top and bottom (or sides) of the gasket. I calked the top edge of the windshield and smoothed and then realized that I couldn't remove the tape until I did the bottom side of the gasket. This led to me always trying to play catch up with trying to remove tape.
To make matters worse my caulk gun wouldn't work with this style tube. The tube appears to be made of aluminum and the first caulk gun I tried to use apparently was a tight fit inside the tube. I was having to squeeze so hard just to get a little bit to come out the nozzle. (I wonder if Peter's ears were burning while I was trying to squeeze the trigger!) I then ran back up to the house and got a different caulk gun which worked flawlessly. I never had that sort of problem before. Unfortunately this delay allowed the top edge that I started on to set up prematurely.
I ended up with a couple of small spots that I will need to redo because I couldn't keep up with the caulking, smoothing, tape removal in a timely manner.
My suggestion is to tape so that you can do the insides seams of both windshields first. Caulk one whole inside half, smooth and remove the tape. Then move to the other windshield and repeat. Once both are done take a short break to let the sealant set up, doesn't take more than a half hour and it seems to be totally cured. Now go back and tape around the outside edges of the windshield. Once taped caulk one edge, smooth it and then caulk the next edge. Now go back and remove the tape from the first edge. Repeat this process until you're done.
I guess you could say I used the Argosy as a test bed since the 310 needs the same treatment.
Hopefully the second time around will go a little smoother!
08-25-2013, 10:07 AM
1979 24' Airstream Excella 24
Tipp City
, Ohio
Brad, Did you purchase the SIKA Tack Moveit from the manufacturer? This is a great link! I want to seal the windshields on my 24' before the weather cools. Thanks, Greg
08-25-2013, 10:18 AM
Richmond
, Kentucky
Greg,
I ended up purchasing mine from the same place Peter bought his in Austin Texas. Unfortunately I don't remember the name of the place. Hopefully Peter will chime in with the name and possibly a phone number.
The SIKA Tack sure seems to be a good product. The important thing I found out is to plan ahead and work FAST and have mineral spirits with plenty of rags available when using it! Oh yeah, get some nitrile or latex gloves, you'll be glad you did
09-11-2013, 08:00 PM
Tipp City
, Ohio
Brad,
I have still not been able to locate the Sika move it. Any chance you can find the receipt and hopefully come up with a phone number? Thanks, Greg
09-15-2013, 05:58 AM
Richmond
, Kentucky
Greg,
I'll see if I can track down where I got it from.
09-15-2013, 07:53 AM
Airstream Driver
1994 30' Excella
Austin
Greg,
The Glass company I purchased the Sika Tack MoveIt from is called Binswanger Glass. They have outlets all over the US, but mainly in the South and south east.
Their Part number: HAH000004
Locations | Binswanger Glass | Your One Stop Glass Shop
It is a "to the trade only" product, since most will fail trying to use, a fact I know Brad can vouch for. I had to put in ear plugs the day he was using it...
AIR #13
01-13-2014, 03:09 AM
Stevelou
1984 27' Sovereign
1984 27' Airstream 270
Wandi
, Western Australia
Thanks Peter we will see if we can get the sealant in Australia. Steve
12-22-2017, 05:51 AM
Richmond
, Kentucky
The original Sika Flex product that Peter used years ago is no longer available and the Sika Flex suggested replacement doesn't do the job. Here's a thread where the sealant issue is covered in detail.
12-22-2017, 05:58 AM
Airstream Driver
1994 30' Excella
Austin
Brad, did you ever apply the black vulkem116 and if so, what do you think?
AIR #13
12-22-2017, 06:40 AM
Richmond
, Kentucky
Not yet. With my Argosy being stored and worked on inside it has not been a pressing issue to apply the Vulkem.
However I did have Ernie seal Peanut's windshield with Vulkem and it appears to have stopped the leaks coming from that area. I had him pry the gasket away from the glass and aluminum and the sealant was applied in the gap and then the gasket was laid back into place. The excess was then wiped up. He did use masking tape around the edges to help contain the mess.
Since the sealant was applied I haven't noticed any leaks coming from the windshield.
