Old 10-16-2012, 12:09 PM   #1
Aluminated
1977 31' Sovereign
1987 29' Airstream 290
Norman , Oklahoma
Images: 14
Talking Solo AC Install
As I stood there looking ten feet into the sky at the top of my 87 290 motor home I thought getting the new Coleman 13,500 AC unit up to it's perch would be impossible for one man, with the never ending advice of my wifely supervisor pushing me on! In a never ending effort to save money I called my local reopair shop and they quoted around $300 to install the unit. My mind was easily made up, but I was apprehensive, to say the least. Then I thought about those poor souls who built the pyramids! Leverage was the key to my success. I parked my pickup truck next to my MH. Then with the parking brake on I extended my 16 foot aluminum ladder from the bed of the truck to the landing zone on the roof on my MH. I tied a rope to the compressor of the AC unit, threw the rope up the ladder to the top rung , looped it around the rung and brought it back to the truck bed and wrapped it around the tie off in the bed of the truck. I pushed from the bed of the truck while my wife took up the slack in the rope and up it went to the top as easy as pie! Laying easily on the roof so as not to dent the fragile skin I took the rope off the new and tied it to the old, and repeated the process in reverse to get the old AC down and into the truck bed. Forty minutes and four big bolts later I was chilling in the Motor home. Another problem solved and three hundred saved!
ericjan2 is offline   Reply With Quote
Old 10-16-2012, 12:29 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Great job Eric. Glad you rose to the challenge. Most of the time we tend to take the easy way out and just write the check. Now you have the satisfaction of doing the job yourself, saving $300 (to fund another camping trip) and sharing your solution here on the forum. A Utube video would have been interesting.
Dan
Old 10-16-2012, 12:57 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Not exactly "solo" but still a job well done.
MICHAEL
Old 10-22-2012, 10:39 AM   #4
Nice!
Yes, it feels a long way up!
Old 10-22-2012, 02:40 PM   #5
First time I replaced the A/C gaskets on our 310 I built a scaffold above the motorhome so I could do everything without touching the roof (yes I have a lot of scaffolding to play with!). I spent more time errecting the scaffolding than I did replacing the gaskets.
The next time I had to replace one of the gaskets I just set a padded extension ladder against the side of the 310 and climbed up and did the job.
This spring when I swapped the air conditioners from the 345 over to the 310 I just used planks that straddled the two coaches and slid the A/C units back and forth.
Bottom line is once you get used to replacing them a time or two it becomes a simple chore.
Ericjan2, good job on coming up with your own solution to the problem. I doubt if any two people will do the job the same way.
1975 24' Argosy Motor Home
