Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 05-03-2012, 04:44 PM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
Need help with electric brake wiring...
I disconnected my brake wiring at the outside of the inner hub on the tag axle. In the heat of the moment on the roadside I thought my brakes had locked up when in fact it was heat generated from bad bearings. Anyways, I have a black and white wire coming from the brake controller and two white wires coming out of the hub. Is there a polarity issue when you make this connection? If so, anyway to do this without taking the hub apart? Mr.D
Mr. D is offline   Reply With Quote
Old 05-03-2012, 04:51 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
There is no polarity problem with the magnet hookup.. Just splice it back together
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
RickDavis is offline   Reply With Quote
Old 05-03-2012, 06:14 PM   #3
Mr. D's Avatar
Thanks, I'm trying to get the MH ready for a Western trip in June. I'd like to do as much preventative maintenance and up keep while I have the luxury of tools, work bench, and parts, Nice to have the forums for a source!
