Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-18-2004, 06:55 PM   #1
demong
Motorhome Pilot
Profile:  Lakewood , Colorado
Motorhome Backup Camera
I need to replace my Land Yacht backup camera. Bought a nice color camera with RCA plugs for connections. Find the old camera had a 3mm 4-pin mini DIN cable. Any suggestions as to how to proceed?
demong is offline   Reply With Quote
Old 08-18-2004, 07:31 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
Now that you already have a replacement camera, you are more or less committed to using it. In the interest of ease of installation, a wireless camera would be great. Can you go to your local electronics supply store, and see if maybe they have some kind of adapter from your new camera to the vehicle's wiring? They probably won't, but it's worth a shot.
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 08-29-2004, 04:40 AM   #3
gwteale
Profile:
Radio Shack
RS has adapters for RCA to Din or the other way.
Rick
gwteale
82 280 Turbo Diesel
A/S # 1A9TDAM20CJ009822
VIN # 1GBKP37W4C3300759
Rear bath, twins
gwteale is offline   Reply With Quote
Old 08-29-2004, 08:37 PM   #4
JohnG
JohnG's Avatar
Profile:
You might be able to trade your new camera back to the place where you purchased it for a new wireless job.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 10-02-2005, 03:46 PM   #5
gunworks
gunworks's Avatar
Profile:  Noblesville , Indiana
Landyacht Backup Camera
Also have camera on Landyacht. What were the symptoms that caused you to replace the camera? Mine has started becoming intermittant while rolling down the road. Is this the camera, or wiring problem? Turn on the unit (Sony) at the dash and get a blank screen. Then anywhere from 5 minutes to 30 minutes later an image pos up which will last from 10 seconds to 6 hours. Off time is getting more predominant over the past three months. Since the cable is sealed from camera to monitor am having trouble deciding where the problem is. Do the cameras wear out?
Thanks!
gunworks is offline   Reply With Quote
Old 10-03-2005, 08:33 AM   #6
gunworks
gunworks's Avatar
Back up camera
What were the symptoms that caused you to buy a new camera. Mine started going intermittent several months back and now will not come on, but for a few minutes during a three hour trip.
Old 10-05-2005, 06:04 PM   #7
GlenCoombe
GlenCoombe's Avatar
Profile:  Sumter , South Carolina
Should be pretty easy to go from the din...cut it off. Take the RCA, cut it off. You will have three wires to contend with. Once is Video. The other will be power and the remaining will be ground. The only problem will be if you have zoom functions and then it gets complicated. If it's just a dumb video setup like most you're in for an easy direct wire fix.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 12:31 PM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 12:23 AM
Intec backup camera Bill McNamara Airstream Motorhome Forums 2 04-15-2004 02:41 PM
Back up camera installation DaveJ Airstream Motorhome Forums 12 12-26-2003 01:36 PM
Motorhome Mechanix Motorhome Mechanix Airstream Motorhome Forums 1 10-27-2002 12:17 PM
