Glen Coombe AIR #8416
1984 28' Funeral Coach
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
I had a blown bag when I purchsed my unit, and replaced them with new Airlift bags. I put them at 55psi, and I don't really notice any differance... What pressure are you guys using? ...and what kind of differance do you feel?
__________________ ____________
Troy Marrs 95 Land Yacht 33
I had the same experience cutting out the old airbags, and stuffing the new ones in that incredibly small hole in the bottom. I can't imagine doing it without the springs fully extended.
Someone mentioned that it was much easier to remove the spring from the suspension to do this job. I don't know how to disassemble the parts neccessary, but it has to be easier than the way I/we did it.
I dropped my springs to replace the bags. You need to pop the lower ball joint. The big thing is to ensure you supplort the control arm with a jack to control the string. I can't imagine stuffing that bag thru that hole!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281 www.balrgn.com
I have had the luck to replace my front air bags twice. I paid a shop the first time and they dropped the springs to do it. I also had to add the cost of a front end alingment to the tab.
The second time, I read the instructions on this forum and it worked like a charm. The way I got the inserts in the bottom was to use the jack to push up the bag. I used a plastic handle off of a toilot auger to pry up the bag. The handle had a hole in it that fit over the schrader valve. Once in half way, a little prying with a wide blade screwdriver and in it went. No front end alingment needed this time.
I also added an Air Lift Dual Command pressure gauge to the system. I ran a new air line to the front and put in a tee. One line went to the inside needle of the gauge to tell me the rear pressure, the other line went to the front needle and the front bags. I can add or bleed air to the front bags with the switch.
My hope is that by knowing the pressure in the system I will not go off "deflated" and ruin another set of bags.
