Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-07-2019, 07:54 PM   #1
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Air relief valve solenoid
This is part of the air suspension system, I understand that it is supposed to relieve pressure downstream from the compressor when the compressor shuts off. Mine has decided to work overtime and release pressure all the time. I plugged the outlet with a screw and plumbers tape today to keep the compressor from having to run most of the time. Has anyone replaced the part? Part number and source? Does my new Viair compressor really need it?
Waipio Rim is offline   Reply With Quote
Old 09-08-2019, 09:08 AM   #2
cmadmaxman's Avatar
1991 35' Airstream 350
Columbia , Tennessee
Images: 40
You should be able to remove it out of the system. My viair compressor does not require it. The pressure relief is built into the compressor.
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
cmadmaxman is offline   Reply With Quote
Fill Tank from City Water Hook-up using clever Electric Solenoid Valve Setup? trekerboy Electrical - Systems, Generators, Batteries & Solar 16 01-15-2015 10:57 AM
Suburban furnace solenoid valve batt LP Gas, Piping, Tanks & Regulators 1 04-05-2012 11:46 AM
water heater pressure relief valve wayne.yl Water Heaters, Filters & Pumps 12 04-21-2007 05:54 AM
Do I need this "second" relief valve? Fyrzowt Water Heaters, Filters & Pumps 20 11-22-2006 11:31 AM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
