Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-28-2006, 07:32 PM   #15
MS325
Profile:  Murfreesboro , Tennessee
Hey Guys,
Thanks for the diagram above, it helped me get the vacuum lines reconnected correctly.
The blower for the dash A/C is not working on the 1985 325 on a P-30 Chassis. I wanted to check with you guys really quick to see if any of you knew right of hand where the blower relay was located. It's probably right out in the open but I have my face crammed into the 5" gap between the dash panel and the dashboard and I don't see it. I found the wiring out of the switch but need to find the relay to check it as well. Thanks in advance,
Mike & Josh
MS325 is offline   Reply With Quote
Winterizing a 345 Motor Home winner Airstream Motorhome Forums 11 09-29-2007 12:56 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
water lines in '73 overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
