Old 04-24-2004, 06:08 AM   #1
idahohanson's Avatar
'76 Argosy Dash A/C
My local RV dealer said that the compressor was bad on the rooftop A/C and recommended a complete new unit. However, they looked at the install and it would take a lot of drilling and etc. to replace.
So, I took it to a local A/C repair shop. Turns out it was the Thermostat, not the compressor ($50 vs $400). He is totally evacuating the old Freon 22, drying it for 24 hours and recharging. Should be good to go.
In regards to the dash A/C. I replaced everything, dryer and compressor. The problem is the evaporator valve that is stuck. Seems the whole coach was built around the metal bax containing the evaporator and labor to cut and get to it is prohibitive (almost $1000 !!). Any easy solutions out there?
Nice to have at least one "cheaper" fix for a change!
Levi Hanson
J Levi Hanson
idahohanson is offline   Reply With Quote
Cable for dash a/c & heater Scott bono Land Yacht/Legacy Motorhomes 4 12-14-2014 10:20 AM
Looking at 24 ft. Argosy crunch27 Member Introductions 6 06-09-2013 07:46 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
Argosy without A/C - options? my3sonsdad Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-28-2011 02:40 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
