Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 08-10-2009, 08:42 AM   #1
spat61's Avatar
2003 31' Land Yacht 30
New Bern , North Carolina
Water Tank Lesson-long read but could help you
I learned the hard way that you should never fill your water tank to the brim prior to a dry camping day out. I normally only load up about 25 % with water, enough to flush etc.
This day, I filled it by accident, right to the brim. I inserted the water hose into the tank fill neck but walked away from it only to realize later that it was full and spitting out the inlet. When I removed the hose, a jet stream of water gushed out.
I thought no more of it until later in the day, after driving about 200 miles, I had wet spots on the trunk carpet.
I removed the mattress and plywood cover and immediately discovered what caused the wetness. First, here is NO overflow drain relief. (Is this normal not to have an overflow drain relief?)Second, the 1 1/4" plug was wrapped with teflon tape but loose. Water was still dripping from the connection. I re-wrapped it with new tape and when re-threading it noted I could not fully tighten the plug. It just wants to keep threading, but not really make a good water tight seal.
Refer to attachment picture. Should I install an overflow drain? Do I need a need new 1 1/4 " plug that would make a tighter seal? Any other advice would be appreciated. Thank you.
Steve
2003 Land Y. Gas
Name:	Water Tank Plugs.JPG
spat61 is offline   Reply With Quote
Old 08-10-2009, 09:35 AM   #2
There should be an overflow relief tube for just such an occasion. The plug should be a tight fit but if it's only a little loose you might try over-wrapping it with teflon tape. This is not a pressurized tank, so it shouldn't take much to keep it from leaking. If the plug is just way too loose I would replace it.
Rich
VIKING is offline   Reply With Quote
Old 08-10-2009, 11:54 AM   #3
1963 24' Tradewind
San Diego , California
You can install a short nipple and put a cap on the nipple
Sixty3TW4US is offline   Reply With Quote
how long to fill black tank? Stefrobrts Waste Systems, Tanks & Totes 14 07-29-2022 09:32 AM
Newby Fresh Water Lesson Learned SSChanger Fresh Water Systems 2 07-15-2009 09:44 PM
How long a shower with a 6 gal water heater? SilvrSausage Water Heaters, Filters & Pumps 16 10-07-2007 06:02 AM
how long on a tank of propane remcolent Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-07-2007 07:09 AM
Clorox in fresh water tank--for how long? Kistler Fresh Water Systems 8 07-17-2004 07:22 PM
