Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 02-11-2019, 11:02 PM   #1
Michael Wild
1978 31' Sovereign
1984 31' Airstream310
Edmonton , Alberta
Replacement Rocker Switch for Aux Heater
Does anyone know where I can find a replacement rocker switch for the Aux Heater that is the exact same as the OEM part?
Michael_Wild is offline   Reply With Quote
Old 02-11-2019, 11:17 PM   #2
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
I wired up a second AUX heater in the back bedroom. I ran the low and high speed fan wires from the AUX heater under the couch. The extra current draw from the second fan motor created too much heat in the rocker switch and burnt it out. I cannot get it to switch off now. The switch moves to the off position, but unless I hold it, it still sends power to the AUX heaters. The Low side still works properly, but I never use it.
If I can find a new switch I will use a relay so the power bipasses the switch.
Old 02-17-2019, 07:32 AM   #3
Magnet18's Avatar
Churubusco , Indiana
Clean work, but you definitely want a relay.
You might be able to take it apart and clean the contacts with sandpaper.
Has there always been a furnace under the bed on your 310, or did you install that?
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 02-17-2019, 07:44 AM   #4
Magnet18's Avatar
I don't have an aux heater in my 310 to compare switches, but what you're looking for is a spdt rocker switch
On this page you can filter by the size of the hole in the dash, should get you close if not exactly the same
https://www.digikey.com/products/en/...=1&pageSize=25
-Rob
Old 02-23-2019, 03:46 PM   #5
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Thanks Magnet, there has always been a furnace under the bed, just replaced it and added the aux heater.
We have been travelling in some very cold temperatures this winter and the second aux heater makes the whole coach very comfortable. Last season when we travelled, we would either have to use the propane furnace to keep the bedroom warm or arrive with a freezing bedroom.
Old 02-24-2019, 06:17 AM   #6
Magnet18's Avatar
Interesting, my 310 came with one furnace and no aux heaters
-Rob
Old 02-27-2019, 06:18 PM   #7
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
I will look through my receipts. I to had to replace a couple of switches. They are a beast to find. Especially the lighted ones. I got a couple of spares. Let me dig them out and I'll get back to you. I think they were like 7.50 a piece where did you get your aux heater from. That's a great idea for the back end. I'll run two switches to the front aux 1 aux 2 I'm going to do the dash over anyway, so new switches are in order for the whole thing. I'm going bigger rocker switches. DJ
davejay is offline   Reply With Quote
Rocker switch- what's it for? Sphere Guy 1993 Excella 1000 2 05-26-2014 08:11 PM
3 prong rocker switch/hot water heater? Lothlorian Electrical - Systems, Generators, Batteries & Solar 5 03-13-2012 09:50 PM
Rocker switch identification Road Dawg 36 Land Yacht/Legacy Motorhomes 7 03-06-2012 02:36 PM
Green Rocker Switch - patio light geodrake Lights - Interior & Exterior 1 11-18-2007 06:16 PM
I_C rocker panel switch does nothing / rocker switches sources for replacements myfirstrv Land Yacht/Legacy Motorhomes 2 11-06-2007 07:26 PM
