Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 03-29-2019, 10:48 AM   #1
coairstream's Avatar
1988 34.5' Airstream 345
Denver , Colorado
Rear Furnace Replacement for a 1988 345 LE
Hey guys after extensive troubleshooting my rear bedroom ducted furnace is shot! It's the small unit on the driver's side behind the bathroom under the single closet door in the bedroom.
It's a Duo-Therm MODEL No. 90130.004 PROD No. 9917508.21, but when I google it for a replacement, nothing comes up, and you're better off finding help at Home Depot vs. calling my local Airstream dealer. I called vintage trailer supply but they couldn't find anything off of the model number either.
I'm sure several of you have experienced the same failure and know of an acceptable replacement. Please advise.
Thanks In Advance!
Name:	furnace pic 345.jpg
Cody
coairstream is offline   Reply With Quote
Old 03-29-2019, 05:01 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
You’re lucky that the Duo-Therm didn’t do you in......they were bad from day 1.....had problems with the heat exchanger cracking and carbon monoxide filling the motor home. Look for a small surburban, I have one that I took out of the rear of the 370LE if you are interested, let me know, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 03-29-2019, 07:35 PM   #3
Denver , Colorado
Hey bob thanks for the reply and I am interested. Please PM me on how to get ahold of you.
Cody
Old 04-04-2019, 06:19 PM   #4
Silver Dreams
stream3's Avatar
Columbus , OH
Here's the proof - this is an image of the Duo-Therm in action in my '88 345LE. A miracle wife and I didn't off ourselves, but it could explain why I'm a bit shy of a full deck. I have a whole new respect for these little combustion chambers!
1988 345LE "Rosie"
-Jerry
stream3 is offline   Reply With Quote
Old 09-21-2019, 01:38 PM   #5
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
I to am now thinking of replacing my stock rear furnace. When I did the front one, I had to fab a plate to adjust for the vent plate being located differently. Does anyone make a direct replacement furnace?
Also. What do y'all think about tankless water heaters. Seems to make more sense than the old tank jobs. My neighbor just bought a new travel trailor and has a tankless heater. Loves it. Any suggestions?
I got so many new parts in this thing, I might as well replace all the old stuff, and be done with it. This coach only has 5000 miles on it, but I suspect it got used a lot sitting. So the furnace, water heater, fridge (replaced) front furnace( replaced) probably got a boatload of time on them. I think I'll just replace the old stuff with newer tech stuff. DJ
davejay is offline   Reply With Quote
Old 05-13-2021, 05:25 AM   #6
Paul J Mauro's Avatar
1985 34.5' Airstream 345
Bolton , Massachusetts
hey bob had a nice trip to rogers rock in the fall and vermont last weekend both cold so guess what rear heat unit is finally giving up .fan squeal etc . looks like you went with a non stock new unit ? since you dislike the duo therms - what fits in there ? or is it a total fab job to modify for replacement ? hope all is AOK with you perhaps we will bump in 2021 local travel this year for us
Paul J Mauro is offline   Reply With Quote
Old 05-13-2021, 11:22 AM   #7
bobmiller1's Avatar
Send me a picture of your rear bedroom so I can see application, Regards, Bob
Old 05-14-2021, 05:49 AM   #8
ok will do
Thx
PJM
1988 Argosy Furnace Replacement Torque General Repair Forum 0 01-05-2019 01:25 PM
1988 Excella Suburban Furnace Replacement Dickandvicki Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-05-2017 02:10 PM
1988 345 shower pan replacement Jim Keaty General Repair Forum 0 03-27-2016 01:33 PM
Replacement Refridgerator - 1988 345 bsdenes Refrigerators 4 12-24-2011 01:17 PM
Rear airbags needed for my 1988 345 motorhome Mr. D Mechanics Corner - Engines, Transmission & More... 2 04-03-2006 03:05 PM
