Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 02-28-2015, 11:07 AM   #1
1982 31' Airstream 310
corrales , New Mexico
Radiator Hose Location Help Needed
looking for help finding radiator hoses for my 1982 310, been to NAPA and GM dealer with no luck.
jackblue is offline   Reply With Quote
Old 02-28-2015, 11:30 AM   #2
Retired.
. , At Large
1982 Chevrolet P30 Radiator | AutoPartsWarehouse
Old 02-28-2015, 12:36 PM   #3
the p 30 hoses do not match up as the lower hose is almost a cork screw. see pic
Old 02-28-2015, 02:22 PM   #4
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Can't Find one right now, but I am pretty sure that I have seen threads where others got around this by buying an accordion type hose of the correct length and letting it bend itself into shape.
Waipio Rim is offline   Reply With Quote
Old 02-28-2015, 02:31 PM   #5
dadstoy's Avatar
_ , _
The top and bottom hoses for the vertical radiator are no longer available. You won't find them anywhere. I found a top hose that was almost an exact replacement and only required about 2 inches cut off on the thermostat side. I don't remember the part number, but you can find it on the thread "dadstoy". I'll look when I get the chance. I was lucky enough to have a brand new lower hose I all the parts my dad had. There are one or two other owners here that have found acceptable alternatives to the original lower hose.
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
dadstoy is offline   Reply With Quote
Old 02-28-2015, 02:36 PM   #6
dadstoy's Avatar
_ , _
The upper hose I used is the Gates 22086 and I cut a few inches off the thermostat end to fit properly.
Old 02-28-2015, 02:46 PM   #7
dadstoy's Avatar
_ , _
Do the following Google search and you will find most the the posts about the hoses. If I remember correctly a couple others have found a solution for the lower hose. Whatever you find for the lower hose, make sure you check to see that the hose at the water pump end doesn't come into contact with the belt that passes right by it. If I push my hose all the way onto the water pump it will contact the belt and will cut the hose. I have very little clearance between the two, but that is fine and it all works great.
I'm also assuming you have the Chevy 454...but I'm guessing most 310's are diesel.
site:airforums.com radiator hose
Old 03-01-2015, 09:19 AM   #8
Originally Posted by overlander63 View Post
Thanks for the info, just bought the MH and trying to my head around it by starting with the simple things (engine) I will check out the gates hose. and the dadstoy thead. you are correct we do have the 454
Old 03-03-2015, 05:20 AM   #9
mprokop87's Avatar
1978 28' Argosy 28
Victor , New York
I have a 1976 Argosy (built on the P30) and had to replace my lower. As far as I could tell there were no [cheap] hoses out there for it. I bought the flexible accordion style hose of the correct length and its worked just fine. Your local auto parts store should be able to get one.
mprokop87 is offline   Reply With Quote
Old 03-03-2015, 06:14 AM   #10
mayco's Avatar
champaign , Illinois
Also you can google "universal radiator hose" and "radiator hose adapters". It will take some patience but you may find something that works for you.
mayco is offline   Reply With Quote
Top radiator hose pvmsteve Land Yacht/Legacy Motorhomes 7 10-11-2016 10:48 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
1975 Argosy 350 cu.in. lower radiator hose source needed 911rs Argosy Motorhomes 8 08-18-2008 10:59 AM
Heater core, Door handle, Lower Radiator hose. josephhh Airstream Motorhome Forums 9 11-19-2003 09:20 PM
