Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 07-04-2003, 05:58 AM   #1
Crsoley Kid's Avatar
Generator problem
Have a 93 Airstream Land Yatch-33ft. 6.5 generator that run out of gas once, since then generator will only run for about one minute at low rpm, then dies. I did remove it and put in new plugs, filters, changed oil and filter. Any other ideas?
Paul
Crsoley Kid is offline   Reply With Quote
Old 07-04-2003, 06:08 AM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
will it run when you have the starter engaged??? if so you have a blown regulator board.. to shut down the gen set under load will blow the regulator board. lol
al
wb13798 is offline   Reply With Quote
Old 07-06-2003, 07:33 AM   #3
Geenerator Problem
Thanks for all the suggestions.I think I have it fixed now,removed the new filter going in to the set and cleaned it, then it would run for 4 or 5 minutes removed it again and cleaned also pumped some gas out to make sure the line was clean. It ran for over an hour yesterday with both AC's running till I shut it off.
Paul
