Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1969-1971 Caravel
Old 06-27-2006, 10:27 PM   #1
1969 18' Caravel
Sevierville , Tennessee
Adding Air to 1969 Caravel-Help
I have purchased a 1969 Caravel and would like to replace the furnace with an airconditioning unit. My trailer will be in Texas quite a bit, and I really need air more than heat. Has anyone done this? Does anyone have any recommendations?
Lone Rangerette is offline   Reply With Quote
Old 06-28-2006, 12:33 AM   #2
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
Ahhhhh, cool air....
Hello,
I am clueless on what exactly to do... I am actually quite mechanically challenged. However, most good folks here are quite talented in that area! My hubby and I have a 1963 Bambi and we have installed a room airconditioner under one of the couches to vent into the cabin. It isn't finished yet so my husband's thread (search NorCal Bambi floor replacement) probably won't give you much... however, I think that the following thread might have details, if I remember correctly. http://www.airforums.com/forum...ler-11687.html
Anyway, I would do a search and read through the threads. Lots of people post pics and all so you can see what they did!
Good luck!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 06-28-2006, 05:36 AM   #3
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
Ac
I just installed a Carrier Air-V (low Profile) unit on my '65 globe trotter.
Here is the thread http://www.airforums.com/forum...ter-23177.html
the job turned out taking a little longe because I had to run power to it.
As for yours, you could look into the air-v and have it sitting ontop, which is likely the most efficient place for an ac. I have seen a unit from Dometic that can be installed on the floor, but you have to cut a hole in the outside. I seriously thought about it but decided to stick with what I've seen work already.
One thing you might consider is a portable unit. If your heater is big enough, when replaced you might be able to slide an AC into it's place. The exhaust could use the existing vent. There are a number of good places online to buy portable units. One site located in texas is called www.compactappliance.com
HTH.
Mud
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 06-28-2006, 02:50 PM   #4
GreatPumpkin's Avatar
Colville , Washington
Images: 70
A/c ?
You could always try and get some advice from these folks :
Sorry, couldn't resist posting this photo. Good luck with the A/C there are quite a few members that have added both rooftop and portable type A/C's, just use the search function above.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 06-28-2006, 06:05 PM   #5
CaddyGrn's Avatar
1963 16' Bambi
1962 22' Safari
Yreka , California
Great Pumpkin,
Your picture is a little red x.... anyone else have trouble viewing the pic? Or is it my ISP again?
Mrs. Nor Cal Bambi (traveling in S Tardis)
Old 06-28-2006, 08:53 PM   #6
1969 18' Caravel
Sorry...your picture did not post.
Old 06-28-2006, 11:31 PM   #7
Images: 70
I did a copy and paste - it shows up fine when I look at it, but I'll upload it this time and see if that works.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 06-29-2006, 09:28 AM   #8
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
SOB's are sure getting ugly.................
Have to say, that's alot of cooling for the small space. Maybe the AC nise cuts down on the generator noise.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-29-2006, 11:30 AM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Do it right
Reference the answer I put in your other posting on this subject.
If you dont have an AC installed already, or if you do, Put in a new Carrier or Duo Therm Penguin. The low profiles! They work great and don't overwhelm the size of the Caravel. The 69 has an interior roof paneling that has two parallel raised areas. A special roof panel has to be made up to make a level interior mounting surface. The 69 has provisions for condensation drain...you will need it here in Texas. If I ever get a camera I will post pics.
Old 06-29-2006, 04:01 PM   #10
1969 18' Caravel
Melody Ranch...do you recommend anyone in Texas to do the work?
Old 06-29-2006, 04:40 PM   #11
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I like these guys
Randy Roland @ North Dallas RV. 800-359-6378. 2630 I-35E, Dallas,Texas , 75006. You will like visiting this place right dead damn in the middle of the worst traffic in the world...has to be....but worth the trip.
Stay in touch.
P.s. I got my AC thru Palomino.
Old 06-30-2006, 07:23 AM   #12
1969 18' Caravel
I worked in downtown Dallas for years with SWBT...family is still in that area. What is a Palomino...keep in mind I am a newbie and a female one at that!! Also, when I say, "I did this...." I am usually referring to hiring someone to have it done...lots of these messages are Greek to me. Y'all will have to say "How would I explain this to my Mother?" for me to understand.
Old 06-30-2006, 07:24 AM   #13
1969 18' Caravel
Where is Kiln, MS? My family originated from Lawrence, CO, MS...still lots of cousins in that area.
Old 06-30-2006, 07:47 AM   #14
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
No where to be exact.
Kiln (pronounced "KILL") is in the SW corner of the State of Mississippi just north of I-10. Closest town of note would be Waveland and Bay Saint Louis. Just a crossroads town with no real industry. Grown some since Katrina with all the displaced people from "The Coast". Great place to live.
I know where Sevierville, TN is and that's a very nice place.
Old 07-09-2006, 12:09 AM   #15
acrane's Avatar
1980 31' Excella II
Stonewall , Mississippi
From Mississippi Too
We are in Clarke County, south of Meridian.
Hope to see some of you when we finally get our 1980 Excella on the road.
alice Crane
acrane is offline   Reply With Quote
Old 07-09-2006, 10:32 AM   #16
Naples , Florida
Trim the interior panel
MR,
I recently installed a Carrier Air V low profile in a '72 Safari. The plastic cover of the 'lower unit' of course did not fit the curve of the interior roof. My solution (after checking with Carrier tech dep't), was to scribe the front and rear to match the curve and then trim the sides (about 1/2"IIRC). The panel then fit the roof contour perfectly and it properly mated to all of the controls as well. It is OK to cut tis cover as long as you do not interfere with any of the control surfaces.
lewster
caravel
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 12-03-2021 09:54 AM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
another Caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
Heater and Air Conditioner jberndt Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
