Originally Posted by SilverWind
Hi. I'm looking for a Step-by- Step Guide to Replacing Shocks on my 68 Caravel.
Any input would be greatly appreciated.
Step #1: Safely lift and support your Airstream.
Step#2: Remove the tire/wheel assemblies.
Step #3: Unbolt the shocks from the shock mounts.
Step#4:Remove the shocks, using the shock itself to bend the axle shock mount outward slightly so it will clear the frame.
Step #5: Install the new shocks.
Step #6: Re-install the tires/wheels.
Step #7: Safely remove the supports, and lower your Airstream to the ground.
