Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Flying Cloud > 1960 - 1963 Flying Cloud
Old 07-20-2015, 09:33 PM   #1
jdlimages's Avatar
1961 22' Flying Cloud
Oklahoma City , Oklahoma
How big is my 1961 waste tank?
I have a 22' 1961 Flying Cloud. Since its that old it only has 1 tank. I haven't used it yet where there wasn't sewer hook-ups. It seems to me to be pretty small. Can anyone tell me how many gallons these early tanks were? Thanks.
jdlimages is offline   Reply With Quote
Old 07-20-2015, 10:07 PM   #2
mandolindave's Avatar
Can't remember exactly
I think it's 16 or 18 gallons. My waste tank lives in the platform beneath the toilet and sink vanity. They are not designed for grey water, although you can route the greywater into the black tank. It's not a good practice as sewage can come up into the shower, and it makes dumping a messy task.
mandolindave is offline   Reply With Quote
Old 07-20-2015, 10:31 PM   #3
I tried to look it up
One spec sheet said holding tank had a estimated one week capacity.
Old 07-20-2015, 10:34 PM   #4
1974 Argosy 20
Kooskia , Idaho
10 to 15 gal most likely, but you can easily measure it yourself. Close the valve, start pouring water into it from one gal bottles. Count the number of bottles until full.
Old 07-21-2015, 04:56 AM   #5
"Cloudsplitter"
Thumbs up
On our 63 Safari I learned my first Airstream lesson....'black tank gallons' are smaller than 'normal' gallons.
I believe ours was 15 that converted to what seemed like 8.
We found the best way to make it work....if the CG had facilities, you were only allowed to use the trailer potty after dark.
Old 07-21-2015, 05:24 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
My 1961 Tradewind has an above the floor tank of about 10 gallon capacity as I recall from pouring jugs of water in it . It will last about 6 days for 2 of us if used carefully.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-21-2015, 05:41 AM   #7
Retired.
. , At Large
Our '63 Overlander had a 10 gallon above-floor tank.
Old 07-21-2015, 11:48 AM   #8
1967 26' Overlander
Spartanburg , South Carolina
My '67 Overlander Owner's Manual says 16 gallons and in parentheses is says "12 gallons on 17 ft models". I've never measured it.
Jacob D is offline   Reply With Quote
Old 07-21-2015, 02:16 PM   #9
jdlimages's Avatar
Thanks for the info. So basically, no showers in the AS unless I'm hooked up to sewer right?
Old 07-27-2015, 06:23 AM   #10
1967 26' Overlander
Sure you can shower if you are in a location that allows grey water on the ground, or if you have a "Blue Boy" portable tank. All Federal area campgrounds forbid grey water on the ground. At least some states do also. The old camping manuals show a plan for a "gopher hole" system that might be permitted some places for grey water.
Old 05-21-2018, 09:55 AM   #11
62 Flying Cloud
VooDooLounge's Avatar
1962 22' Flying Cloud
Lakewood Ranch , Florida
How can I divert the grey shower and sink water out to grass and bypass black tank in my 62 FC? (When not in campground/public)
VooDooLounge is offline   Reply With Quote
1961 BAMBI :: 1961 Airstream BAMBI DUNSKI Airstream Registry Discussions 0 08-19-2011 08:31 AM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
