Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Click Here to Login
Old 03-06-2002, 11:25 PM   #1
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Picture series-exterior panel replacement
Don't try this at home!
Thanks go to Andy @ www.inlandrv.com for making sure, I got the right panels and
Dan Bailey of TDRV in Austin, 512-970-9185
PeterH-350LE is offline   Reply With Quote
Old 03-07-2002, 12:05 AM   #2
66TradeWind's Avatar
Images: 22
Wow!
Incredible Peter !
How many hours went in to the replacement of panels? Very ambitious project.
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
https://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 03-07-2002, 10:15 PM   #3
Airstream Driver
1994 30' Excella
Images: 49
1500 rivets, 5 tubes of vulkem, many drill bits,3 people for 2 weeks for panel r&r, 1 day for stripping paint of the windows, then 1 person (me) shaving rivets for 3 days. And still countless hours left for detailing and pin striping.
Was it worth it?
YES!
Would I do it again?
Hmmm.....
Putting a rivet in new skin, is like trying to stick a needle into a balloon.(Without the balloon blowing up)
You can easily develop a strong dislike for yourself.
Old 03-08-2002, 01:51 PM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Peter,
In the sixth photo it looks like you are putting the new panel over the old one. Did you remove the old one or is it still there???
Just my curosity
Brett
thenewkid64 is offline   Reply With Quote
Old 03-08-2002, 03:24 PM   #5
Airstream Driver
1994 30' Excella
Images: 49
Brett,
good observation on that panel. But, no, it is not there anymore.
The problem on the 18'9" panel is trying to cut out the windows and the door on the ground and then getting it in place without creasing it.
So, instead all the rivets were removed from the old panel and it was only held in place by some screws on the bottom row. Then the new panel was put in place, like you see in the picture.
Now the windows and the door could be cut out from inside the coach, using the old panel as a template, insuring excact placement of the windows and door.
At this point the screws at the bottom row could be removed and the old panel carefully slipped out from under the new one.
Old 03-20-2002, 08:01 AM   #6
mwendell's Avatar
wow!
this is awesome peter, thanks!
m.
mwendell is offline   Reply With Quote
Old 03-23-2002, 09:24 AM   #7
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Lightbulb Exterior panel replacement
Peter-
Would you mind sharing the sheet aluminum specifications with us?
Rob & Shari
InsideOut is offline   Reply With Quote
Old 03-23-2002, 04:34 PM   #8
Airstream Driver
1994 30' Excella
Images: 49
Rob & Shari,
Sorry, I may not understand your question.
Do you mean thickness of the panels?
All the panels are year specific. I actually called AIRSTREAM, to get the part numbers for my year. They gave me the wrong part number for the big upper panel (307" long). Master Andy from InlandRV saved my day, catching their mistake. The panel they told me to get would have been some 4" too short (the heights, not width).
The thickness of the material is .040"
It comes precoated from the factory (new alcoa coating technique) and has a protective film, which saves you during installation.
It matches the old original panels from 1979 rather well.
I hope this answers some of your questions.
Old 06-03-2002, 01:29 PM   #9
Skin over Skin
Peter,
What about placing new skins on top of old skins, leaving old skins in place? I have three upper nose skins I would like to replace some day and have been pondering this. This is on '84 Excella 31'.
Neal
NSMITH is offline   Reply With Quote
Old 06-03-2002, 04:51 PM   #10
Neal. They won't fit under the roof and window sheets. Also, you would not be able to inject the vulkem sealer, underneath the seams.
The only real way, in your case, is to bite the bullet and do it the "proven way."
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Attaching a single picture to your post PeterH-350LE Forum Admin, News and Member Account Info 62 12-04-2004 10:44 PM
Classic Airstream Motorhome Picture Archive RichardT Airstream Motorhome Forums 0 11-09-2003 06:36 PM
Adding a picture to a post wallybyam Our Community 5 03-03-2003 07:29 PM
