Old 11-06-2002, 07:06 AM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Send a message via AIM to Pick
Axles are now expensive too.
I called Henschen to order my axles yesterday. I had gotten a quotation from them a few months ago at $430 for axles complete with hubs and brakes. Now they tell me I have to purchase them through Inland RV. His price is $800!!!! I about blew a cork.
ARS WA8ZYT
2003 GMC 2500HD 4X4 D/A Ext. Cab
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Pick is offline   Reply With Quote
Old 11-06-2002, 09:05 AM   #2
There "is" a difference between "wholesale" and "retail."
Henschen decided to get "out" of the replacement market as it became too time consuming. They now sell to "OEM'S" only.
Also, Pick, did you check Airstreams price?
You will find it to be greater than ours, as a matter of fact $103.00 more.
They are not in the wholesale business either.
That doesn't make anyone a bad guy, it just means the wholesale availability is no longer available.
However, someone has gone to Southwest Wheel to obtain a replacement axle, who will sell wholesale. If you can engineer the axle and it's required attachment changes, shock bracket size and location, along with determining the necessary adjustments and attachments that you must make in order to install it, then you can get a complete axle, you determine the rating, along with hubs, drums, bearings and brakes for less than $300.00.
The photo's of your Airstream clearly show that your axles are gone, as indicated by the top of the wheels not being visible, as it should be.
Your trailer will be the judge of your decisions, in terms of does it like the different ride, as well can it handle the different length torsion arm. Additionally, since the length of the torsion arm from other axle manufacturers is different from Henschen, will the tires fit within the wheel wells properly.
My information says no, but I am not an engineer either.
inlandrv.com
airstreamparts.com
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is offline   Reply With Quote
Old 11-06-2002, 12:37 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
North of Boston , Massachusetts
Images: 260
Hmmm..."top of the wheels not showing".....don't like the sound of that. It should sit up that high?
I did check the torsion arms, and they still seem to have a little bit of an angle left on them.
which reminds me: I saw the axle plant tour on your website; one of their drawings of the axle seems to indicate that the torsion arm should be 90 degrees with a load. your article on the subject says they should have a + angle....care to clarify?
Chuck is offline   Reply With Quote
Old 11-11-2002, 08:06 AM   #4
Chuck.
Reviewing our article on axles, did not list any comment that a positive angle was OK.
Any positive angle could be a problem, depending on the payload.
A change in our article will indicate that the maximum travel of the axle shaft with the envelope designed shaft is 42.5 degrees. With the square shaft design, the maximum travel is 35 degrees. The square inner shaft was first used in the mid 80"s.
From mid 80's and older, the maximum positive angle is 17.5 degrees.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-11-2002, 09:19 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
On this page: http://www.inlandrv.com/tours/axle-p...s-briefing.htm
toward the bottom of the page, the graphic labeled "22.5 degree starting angle", shows that the normal load position is horizontal.
Your article ( http://inlandrv.com/articles/dura-torque-axle-92001.htm ) says,
"Each axle has a maximum weight rating. When the trailer is loaded to the maximum weight rating, the torsion arms should still maintain a rearward slight negative or downward angle, but never more than a zero angle (parallel to the frame)."
Put more simply, my trailer's torsion arms appear to be horizontal. is it time for new axles?
Old 11-11-2002, 09:26 AM   #6
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Chuck, I would GUESS no, if both sides are even.On my Airstream the drivers side arms are at the zero, or level angle. On the curb side they are at a negative angle. If I look at my tires and wheels I can see that the trailer is about an inch or more lower on that side. Could be due to the fact that the fresh water tank, kitchen, furnace, tub/shower is all on that side of the unit. On the driver's side they seem to look "normal" judging by all the pictures of other Airstreams I have seen.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-11-2002, 09:37 AM   #7
Chuck.
If the torsion arms are parallel, with the trailer loaded, they are OK, but bear watching periodically.
If the torsions arms are parallel with an empty trailer, that indicates that the axles are gone.
However, some owners travel very light and others travel very heavy.
We suggest that you check your axle arms when you have the trailer loaded for travel, and hooked up to your tow vehicle.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-29-2002, 10:25 PM   #8
Forrest's Avatar
Aurora , Colorado
Images: 21
Thumbs up How & why I replaced mine.
First off I have to say that while I've balked at some of Andy's prices it hasn't been because he's gouging us -- It's just that I'm retired and have a fixed income. So, I have to be a little frugal. A big POSITIVE for Andy is that he really does know what he's talking about and I've learned a lot from his Web site! For instance I asked Windish RV (Denver) about replacing my axle for me. Their "expert" didn't even know what the conditions were for a worn out axle. He told me he'd never heard of positive angle. Now I suppose he knows, but it convinced me to do the replacement my own self! Here's a picture worth a thousand words. It is the new and old side by side in my pickup just before I took it to the welder to have the shock brackets welded in place. Guess which axle is worn out??
Name:	old & new, b.jpg
Forrest is offline   Reply With Quote
Old 12-29-2002, 10:33 PM   #9
Forrest's Avatar
Aurora , Colorado
Images: 21
Thumbs up Installation tip.
Here's a photo of how I maneuvered the new axle into position under my Globetrotter. I used a 3 ton jack that has a wide plate on the lift. The axle balanced better than I thought it would, but take it slow. I did it without any help, but it would have gone faster with another (knowledgeable) person to assist.
Name:	new install, b.jpg
Old 12-29-2002, 11:17 PM   #10
Silver Bullet's Avatar
THAT'S IT!!!!!!
Your (old) mounting plates are the same as mine. Did you have to redrill new mounting holes to accept the new axle? Oscar
Silver Bullet is offline   Reply With Quote
Old 12-29-2002, 11:25 PM   #11
NewStreamer's Avatar
Thumbs up
Very interesting pics,
Where are the brackets welded? Did you replace the brakes & drums?
Ron
NewStreamer is offline   Reply With Quote
Old 12-29-2002, 11:46 PM   #12
Forrest's Avatar
Aurora , Colorado
Images: 21
Thumbs up Axle replacement tip
Yes, I had to drill new holes, and I replaced the brake assembly and wheels and tires. Don't make this mistake: When I took the axles in to the welding shop we copied the position of the shock brackets from the old axle. It seemed like the logical thing to do, but I didn't take into account that the new axle has a slightly different configuration. It mounts about 1 inch farther away from the frame than the old axle. So, after I mounted the new axle I discovered that the new OEM shock absorbers were - you guessed it - one inch too short. But like the old saying goes - when life hands you lemons - make lemonade. I found better, and larger air shocks at NAPA. I've read that the OEM shocks are hard to come by, but now I have shocks that can be bought just about anywhere. They also come with a life time warranty. The OEM replacements from Inland don't. Here's a photo:
Name:	shocks extended, a.jpg
Old 12-29-2002, 11:51 PM   #13
Forrest's Avatar
Aurora , Colorado
Images: 21
Angry OEM shocks too short
Here's a photo of the too short OEM shocks. You can see the mounting bolt and welded bracket just beyond its reach.
Name:	shock oem - too short, b.jpg
Old 12-29-2002, 11:54 PM   #14
Forrest's Avatar
Aurora , Colorado
Images: 21
Gas shock installed
Here's the gas shock installed.
Old 12-30-2002, 12:29 AM   #15
It must feel gooooood now! I envy you
Ron
Old 12-30-2002, 06:42 AM   #16
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bump stop?
forrest,
did your old axles show any signs of hitting the bump stops?
i just noticed them in your installation photo.
also, are the new axles a higher rating than the old one(s)?
the new axle looks beefier in the swing arm area.
john
john hd is offline   Reply With Quote
Old 12-30-2002, 06:47 AM   #17
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
also
forrest,
few more questions,
did you drill the axle or the frame of the trailer? or both?
and what type of bolts did you use? they look anodized, are they grade 5,8 or 10?
john
Old 12-30-2002, 07:54 AM   #18
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
Axle Bolts
John, when I ordered my axles from Inland, they shipped with grade 8 bolts. Mine are still setting inside, waiting for a break in the weather here before I tackle the job.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-30-2002, 09:33 AM   #19
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I'm confused
Forrest, what kind of axles did you buy (Pick bought Inland axles). From another post, it seemed like you bought axles from Inland, but judging by the modifications, you bought another type? Also, in looking at your photos and at your posting, you state, "the new ones mount 1" away from the frame." In what direction, front, back, or 1" more "drop?" If it does mount 1" forward or back, how did you determine that the actual axle is in line where the old one is. I'm guessing that the old crossmember and new crossmember just locate in the same "u-holes" in the frame? I looked at the new/old axles photo - I'm guessing that you needed to drill the front and rear holes in the frame (using the new axle mounting plates as guides, as the front/rear axle plates are longer and the holes more widely spaced? If these were not Inland axles, can you post an approx cost?
Thx,
Marc
3Ms75Argosy is offline   Reply With Quote
Old 12-30-2002, 10:16 PM   #20
hex
hex's Avatar
Question Also a bit confused
Forrest a few more q's if you don't mind :
first where did you get the shocks that would not fit?
Are they going to let you return for credit?
What brand are the OEMs that don't fit?
What was the cost of shocks OEM, and of the Henschen Axle?
How much shipping cost? Was it shipped from Inland or drop-shipped direct from factory with billing thru Inland?
Now about the diagonal piece that is welded to the frame mounting plate;
Was this added to give you an upper shock mounting surface? or is it original? How far up into the wheel well does it extend and is there a stud welded or a hole to accept a bolt at top? It appears in your photos to have a rib down its center. or looks like a piece of angle that has been flattened to some degree. Is this correct?
Lastly the (angled) mounting brackets on the axle have two planes. One obviously lies against the frame mounting plate, and is bolted on horizontally.
Are there also bolt holes in the top plane,that would bolt up (vertically) thru the bottom leg of the frame C-channel? I don't know how one would get to the nut side but my Service manual shows the vertical bolt holes as well. Different year, different axle though.
Great photos! Thanks for sharing.
hex is offline   Reply With Quote
Duratorque Axle Replacement Andy R Axles 18 03-19-2017 08:54 PM
Axle replacement finished uwe Axles 55 11-05-2011 10:21 AM
POLL: Axle Replacement Safari Tim Axles 45 01-30-2006 09:02 PM
Axle Replacement ??? FC54 Axles 6 10-10-2003 05:01 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
