Old 09-15-2002, 07:57 PM   #1
1962 19' Globetrotter
2001 31' Excella
Looking for pump part
The water pump is the orginal on my 78 Excella and works great. Only problem is the bottom plate is cracked and leaks.
The pump is the PAR 36800. I only need the bottom plate. It's the plate on the bottom of the pump, black, attached by 9 screws, and it measures 4" x 4 5/8". The plate has a # on it - C5623.
Anyone have one from a pump they replaced???
Craig is offline   Reply With Quote
Old 09-16-2002, 09:01 AM   #2
2001 31' Excella
Just wanted to let everyone know - Jabsco makes the PAR replacement water pumps, which cost about $230. Anyway, I called a Jabsco Service Center to see if I could get the bottom plate for my water pump (which was made in '77). And they had it! So, before you replace your PAR/Jabsco water pump with a lesser model, call one of the Jabsco Service Centers.
Old 01-09-2008, 01:43 PM   #3
1979 23' Safari
Centerville , Ohio
par pump parts
thanx to this forum I found the below listed vendor for a complete rebuild kit for my par 36800 water pump from my '79 Safari
C.E. Beckman Co.
New Bedford MA
508-994-9674
Very courteous, had a complete kit in stock ,freight and all less than $100.00
I would highly recommend them. Also thanx again for this forum for its great way of sharing info. Jeff C.
jeftec is offline   Reply With Quote
