08-28-2002, 12:40 PM
#1
Vulkum or Silicone??
I have found several threads addressing the installation of Fantastic fans but I can not find any information on the type of sealer they used. Vulkum, Silicone or some other product?
Thanks in advance for any information.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
08-28-2002, 01:56 PM
#2
1984 29' Sovereign
Savannah
, Missouri
Sealer
Jerry,
The sealer to use is: SIKAFLEX, Part #360180 from the A/S factory, cost is $8.15
Good luck
Vern
WBCCI 5292 AIR 807
NEU #64
New England Unit
08-28-2002, 05:19 PM
#3
Vulkem or Silacone
I have used Vulkhem for many years on my Airstream, and around the house.
It lasts extremely well, it sticks better than any silacone I have ever used.
A trick is to use a dishwashing soap and water mixture to
smooth the surface with your finger, it also causes the caulk
to "skin over quicker".
Also, once opened the tube will cure in a few weeks. To prevent this, put it in a sealed kitchen bag (I double bag mine) and then store it in a freezer, it will last for years this way. Just thaw it by
letting it sit out overnight in the sealed bag.
K L Stone
08-28-2002, 05:59 PM
#4
1984 29' Sovereign
Savannah
, Missouri
REPLIED TO QUESTION
"I have found several threads addressing the installation of Fantastic fans but I can not find any information on the type of sealer they used. Vulkum, Silicone or some other product?
Thanks in advance for any information."
Your 'original question' adressed the seal used in the installation of 'Fantastic Fan'. Since I had just had two Fantastic Fans installed at the A/S Factory, I wanted to share with you the "correct" sealer info you requested.
It appears to have been a waste of time.
WBCCI 5292 AIR 807
NEU #64
New England Unit
08-28-2002, 08:08 PM
#5
1965 20' Globetrotter
Houston
gwsullivan:
Never use Silicon based products on aluminum. It will turn a real nasty grey and eventually fall off, if you are lucky.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
08-28-2002, 10:03 PM
#6
Vagabond
1973 31' Sovereign
Fort Meade Md. RV park slot 8!!
, Motorsports Photographer
SikaFlex for gaps and fittings?????????? Help me out need more intell on the SikaFlex!!!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
08-29-2002, 08:23 AM
#7
1967 22' Safari
Coquitlam
, Beautiful BC
I used Sikaflex for areas on my trailer above my windows....i.e. rooftop vents;pipe vents etc.It's a lot thicker and stickier to use than Vulkem but I have been told it holds up for ages.I would not use it for skin panel seams or tiny areas.....Vulkem or Parbond worked much better for me in those applications....but I recommend Sikaflex for bigger gaps that need caulking,especially on your roof.
08-29-2002, 01:09 PM
#8
Vagabond
1973 31' Sovereign
Ok, but where do i find some!!!!!!!!
08-29-2002, 02:52 PM
#9
1967 22' Safari
Coquitlam
, Beautiful BC
The product is called "Sikaflex 227".It comes in a few colors.....clearly the "aluminum grey" being the one for us Airstreamers to use.
I purchased mine from:
http://www.cascadeaqua.com/index.html
I am in Canada,and this is a Canadian company.For a US supplier,I would do a search or go to :
www.sika.com
Should be able to locate some near you.
08-29-2002, 02:58 PM
#10
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
, Colorado
The second post (by Towner7) in this thread states that it's available from the Airstream Factory...thanks Vern ~
Shari
08-29-2002, 04:25 PM
#11
1984 29' Sovereign
Savannah
, Missouri
Ref
Shari,
You're very welcome...
WBCCI 5292 AIR 807
NEU #64
New England Unit
08-29-2002, 10:51 PM
#12
Vagabond
1973 31' Sovereign
DAAAAAAAAAA!!!!!!!!!!! I read all the posts, But was asking if any one had found it some wear other then" Airstream"
08-29-2002, 11:46 PM
#13
1956 22' Safari
Conifer/Evergreen
, Colorado
Sorry DaPlumber ~ I certainly didn't mean to offend you...I just thought you might have overlooked the earlier post...
Shari
08-30-2002, 12:00 AM
#14
Vagabond
1973 31' Sovereign
"InsideOut" Its a Airstream thing!!!!!!!! Is AOK... You did not offend me. LOL
09-01-2002, 11:40 AM
#15
towner7 (Vern), your advice did not go unnoticed. I have been 'off the net' for a few days. Thanks to all who answered. I will attempt to contact the factory next week and order some sikaflex.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
09-01-2002, 03:38 PM
#16
1966 26' Overlander
Woodstock
, Georgia
thanks for the info y'all. I used Vulkum and also Dupont Aluminum sealant from Home Depot, and both went well and look good.
The aluminum sealant shines and blends well. The idea above for saving the vulkum in the freezer is a good one...thanks, and also I used mineral spirits to wipe down the vulkum as I put it on, but the dishwash liquid idea would be a great one to try next time- much less worrisome I bet.
09-12-2002, 02:26 PM
#17
Removing Silicon
I need to remove my fantastic fan annd intend to replace the current silicon with vulken. Any suggestions for removing the old silicon? What breaks it down?
Thanks!
Charles Willson
Santa Cruz, CA
64 Globetrotter
56 Caravanner
09-12-2002, 02:33 PM
#18
1984 29' Sovereign
Savannah
, Missouri
breakdown
I've used alcohol with the greatest of ease...Plus an old toothbrush to help "get at it"..The main thing is to get all of the old silicone up as Vuklum will not stick well to it..
I'd recommend keepin lots of clean rags handy..
ciao
09-25-2002, 05:33 PM
#19
Sikaflex
Sikaflex is commonly used in the marine world, so if you have a marine store or boatyard handy you might look there.
11-10-2002, 04:31 PM
#20
WanderingMinstrel
1971 31' Sovereign
2007 25' International CCD
2005 28' International CCD
Shadow Hills
, California
For what it's worth, I spotted the following on another website.
AIRSTREAM INC.
We use and sell Vulkem 616/631 sealant, only. We have it available in both gray and black. We do not recommend any other sealant for the exterior shell other than Parr Bond, or Sikoflex.
SOURCE: Airstream Service and Parts Department
And here's a link for more information:
http://www.airstreamdreams.com/generic.html?pid=29
Duane Abler
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
silicone removal
sibyrnes |
Cleaning, Stripping & Polishing |
3 |
06-01-2005 07:52 AM |
silicone inside
Ghost Rider |
General Interior Topics |
1 |
03-21-2004 09:48 PM |
Blobs of silicone on screws?
Kistler |
Our Community |
9 |
06-24-2003 08:06 AM |
Vulkum
ALANSD |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
1 |
03-20-2003 10:24 AM |
Vulkum
ALANSD |
10 |
04-22-2002 05:46 PM |
