09-30-2003, 09:56 AM
#1
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
, Colorado
Individuality...CA vs OH
Subtitled "CA vs OH"
I was just reading a post that was dicussing the differences in window frames...I too am amazed at the differences between the "exact same vintage models" that were made in CA or OH. Actually, even two trailers made in CA only 30 serial numbers apart, are very different...for the record, ours was built in CA. Below are my observations from a VAC Rally a year ago when we had several "twins" in attendance:
Nothing is "special" about being made in CA except that the CA factories were first because that's where Wally lived. By '64 both CA & OH were in full-swing. I don't know off-hand when the OH plant opened or when the CA location closed, but I do remember driving by the Sante Fe location as a kid. And Rob (Mr. InsideOut) lived about 10 minutes from the CA Plant. I was born in OH, but I don't remember seeing them as I moved from there to CA in '63 when I was 4.
As far as some of the minor differences between CA & OH, we have a friend who has the exact same CA model and year as Maxwell and another with a OH one. We were all at a rally last summer where there was also another OH '64 GlobeTrotter in attendance. We were able to compare them all side-by-side. We were amazed at the differences between all four, even between the two OH units and the two CA units. Essentially they were all the same, but here a re some of differences:
Heaters...both OH units had Furnances w/thermostats & CA just has a on/off heater.
Cabinets...although the same design, they were different...three doors on our CA overheads, and four on the one of OH ones & three on the other. Also the cabinet height was different, both OH units were shorter. So all four were different.
The windows were different size...CA generally were bigger but the other ones didn't match either...the frames are completely different between the CA & OH, and there were other differences in size too. I don't recall the precise sizes, just that they were different. We were all amazed...no two were alike!
The exhaust hood & vents over the stoves were different, CA went out the top, OH out the side.
The stoves are also different, ours is four burner as was one of the OH ones, the other OH one had three.
The toilet & shower fixtures were different too, one OH had been replaced, but the other was original & different than Max.
Anyway...Neither one or the other was "better" just different...like the factories just used the local folks in each location.
Oh yeah, one other thing, CA had clearcoat & OH did not. One big advantage of the OH units.
Some of the other years, 50's models I think, they had different shaped wheel wells between CA & OH. Also they had different rear ends (whale-tails).
If you are interested in these things with the older units, a great site to check out is http://www.vintageairstream.com/archives/index.html Some of the archives show & explain some of the differences.
Unfortunately, I did not take photos to document each of the differences...maybe sometime I'll spend the time to do so...
Enjoy!
Shari
09-30-2003, 03:11 PM
#2
1968 17' Caravel
Battle Ground
, Washington
One one of the recent Caravel threads rluhr and I were comparing our bathrooms and found the shower pans were quite different, despite ours both being 68s, which was a surprise to me.
How can you tell if your unit was made in OH or CA? I assume mine was from CA since it was purchased new her in the NW.
Stephanie
09-30-2003, 03:43 PM
#3
Very interesting thread...
Roger (85MH325) and I both have Ohio built '63 Flying Clouds, and the serial numbers are only 4 numbers apart. We're guessing they were probably finished the same week, if not the same day. His trailer has the oval Grote marker lights, and mine has the teardrops.
The Cal built '63 FC that was at the LaVeta rally had some significant differences in the interior, including a different style of heater, refer, and some differences in the cabinet configurations.
Sounds like the early Airstream production crews took a practical approach to finishing out the trailers, and used whatever "trim pieces" (thermostats, lights, etc) were available at the time.
The nice part of this is that it makes it easier to restore a vintage Airstream to "original" condition. With no clear "standard" for some of the smaller parts, a restorer can use whichever part he/she can find, and still be "true to the breed." Can't do that with a '57 T-bird or a '55 Chris Craft.
09-30-2003, 03:58 PM
#4
A partial answer to your question, Steph...
The two plants used different serial numbers on the earlier trailers (thru '65, I think). RJ's photo archive is down right now, but it sets forth the different serial number "ranges" for each plant during these years.
In '65 (I think), the serial numbers were standardized between the 2 plants. Don't know how you could tell a '68 Ohio built from one made in California...
(PS-why does it matter?? Are you looking to have an exclusive CALIFORNIA Caravel rally so you can exclude the Ohio Caravel types???? )
Tom
09-30-2003, 04:52 PM
#5
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
serial numbers
Stef, you probably saw my post on the window thread, but just to answer your question.... the serial # format on the late 60's Caravels should be like this:
1st letter: O or I (Overlander or International trim)
2nd and 3rd digits: 17 (17 feet long)
4th digit: model year (8=1968)
5th letter: factory. J=Jackson Center OH, and I think S for Santa Fe, CA
6th-8th digits: production #
So mine is O178J144, the 144th unit produced in 1968 at Jackson Center.
-- RL
09-30-2003, 06:51 PM
#6
Don't touch that...
Tom,
I know I really cant speak for Steph but knowing her from this
forum I rather doubt it. The whole idea came up just because the few "Caravelers" on this forum have been swapping stories a bit and wanted to meet. I don't think any of us want to exclude anyone. You never know who may be your next new friend. (Resisting the temptation to punctuate with "emotions.")
Heidi
09-30-2003, 10:35 PM
#7
1968 17' Caravel
Battle Ground
, Washington
Don't worry, I can take the ribbing
Actually I wanted the Caravel rally to include any old vintage who wants to come (aw, heck, I wouldn't even turn away a new 'streamer)...
So anyway, my serial number decodes to
Overlander
17 ft
1968
Santa Fe, CA
#128
Cool, thanks rluhr!
Stephanie
09-30-2003, 10:51 PM
#8
1956 22' Safari
Conifer/Evergreen
, Colorado
Actually...your "O" doesn't stand for Overlander. An Overlander is the 26' long trailer model, not an option package.
Shari
09-30-2003, 11:33 PM
#9
1968 17' Caravel
Battle Ground
, Washington
Yeah, I wondered what that would mean. What do you think the difference between and I and an O would be in the first position in the serial number? Maybe they're just 1s and 0s.
Stephanie
10-01-2003, 06:05 AM
#10
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
Actually it does stand for Overlander
I got that directly from Airstream. See their document on "Pre 1980 Serial Number Identification" at http://www.airstream.com/airstream/p...pre1980vin.pdf
I think over the years with all the model name and trim line changes, Airstream has made it clear they reserve the right to "not make sense" on a regular basis!
-- RL
10-01-2003, 07:20 AM
#11
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Stef, Stef, Stef... I just don't know what's happening here any more. That's just NOT the proper Airstream snobbiness that's (apparently) expected of we Airstream owners... what IS this; a new sense of inclusiveness??? What ARE you thinking? Whatever IS the world coming to?
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
Former Airstreams: 1953 Flying Cloud, 1957 Overlander, 1961 Bambi, 1970 Safari Special, 1978 Argosy Minuet, 1985 325 Moho, 1994 Limited 34' Two-door, 1994 B190 "B-Van"
10-01-2003, 07:29 AM
#12
2004 22' Interstate
Tipton
, Iowa
differences...
While I had and was "semi"-restoring my '61 Bambi, I looked at a number of other Bambi's from '61 to '63, both on-line and that were owned by VAC members. It was immediately apparent that one of the major differences between the OH and CA coaches in the Bambis is that the OH coaches (mine was OH) had a the galley streetside, and the CA coaches were mirrored with the galley curbside. There were a number of other minor differences as well.
It is apparent from looking at a variety of units of different models built in both factories over the years that they used parts from different suppliers; either suppliers that were closer or who had product ready to ship when Airstream needed the parts. As the trailers were built by hand rather than true assembly-line manufacturing, it wasn't a problem to customize openings for windows, appliances or whatever they had on-hand to install. There are also some obvious features on some trailers that were only done in limited numbers either because the suppliers couldn't keep up with demand, or Airstream wanted to try something to see how it would sell or hold up. The Argosy line is of great interest for me because it was the test-bed for many of the features that showed up later in the silver trailers. Conversely, many of the Argosy features never carried over for one reason or another.
Personally, half the fun of owning and looking at vintage coaches is finding the variations within the line.
Roger
10-01-2003, 07:55 AM
#13
1956 22' Safari
Conifer/Evergreen
, Colorado
I agree!
We almost make a game of it...that's the point I was trying to make, I LOVE the individuality of each one! They are as unique as their owners...
Shari
10-01-2003, 09:13 AM
#14
1948 16' Wee Wind
1953 21' Flying Cloud
Denver
, Colorado
"O" should not mean "Overlander"
With all due respect to Airstream, I think they got it wrong by stating on their web site that the "O" in 1966-68 trailer serial numbers means "Overlander". I think it represents "zero" (or a null place holder) and means a standard trim "Land Yacht" trailer. The "I" is a capital letter that signifies "International" trim was installed in the trailer. The factory is identified by the preceeding (first) letter of the serial number.
Factory catalogs for all three years 1966-68 list only two trim levels, the standard "Land Yacht" and the upgraded "International Land Yacht". In all three catalogs, "Overlander" is the 26 foot tandem axle model name, not a trim level. I think the purpose of the "O" in the serial number is simply to hold the place (or space) open when an "I" was not appropriate. Contemporary (66-68) factory literature expressly contradicts the explanation given today on the Airstream web site. Whoever prepared the web site apparently did not review 1966-68 factory sales literature before coming up with their explanation.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life "From the Archives"
10-01-2003, 09:14 AM
#15
Re: Caravel Rally
Heidi & Steph,
I was just joshing about the Caravel rally. It actually sounds like a great idea. I apologize for my rather undeveloped sense of humor.
Tom
back to "Differences"....
10-01-2003, 01:28 PM
#16
1968 17' Caravel
Battle Ground
, Washington
I knew you were pulling my leg, you had a smilie on the end of it!
I'll try to be more exclusive Roger, I know I'm lettin' y'all down. Must be my extensive Mustang background! I find I'm not fitting in very well in the vette crowd either...
I agree Shari, it's neat to see all the differences in the coaches. I haven't been lucky enough to find a 68 Caravel in our travels yet, but it's been fun to see other vintages. I can't wait to get to a real vintage rally next year!
Of course the other difficult thing is figuring out what was original and what was added over the last 20-30-40 plus years. For example, my caravel has a 'Land Yacht' emblem on the back between the taillights. I haven't seen another like that, and NewKid64 thought it was probably added by a PO.
What does International trim mean, anyway?
Stephanie
10-01-2003, 02:08 PM
#17
1956 22' Safari
Conifer/Evergreen
, Colorado
Steph, I have seen the Land Yacht between the tail lights before...as a matter of fact, I just checked and it looks like most of the '68s on the vintage archive website have it, sorry Brett.
Also, here's an old thread that kinda gets into the whole "International Upgrades" thing. Enjoy!
Shari
10-01-2003, 02:17 PM
#18
1977 31' Sovereign
Tampa Bay
You've got me curious now. I just went and got my registration for my 1972 Overlander, and as it turns out, it was made in California... now residing in Tampa Florida. I was wondering why I enjoyed the bean sprouts and yogurt sandwich on whole wheat bread so much while out in my trailer. And who knows, if things go Arnold's way, maybe "I'll be back!"
Hasta la vista baby!
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
10-01-2003, 02:32 PM
#19
International package
Steph:
The '68 catalog gives the details of what was included in the International package that year. The catalog is available at the VAC website, under the "Online Library." (The site is probably being worked on at the moment, as access is somewhat intermittent.)
The following are listed as the International upgrades for '68:
water purifier; ceiling fan; stove exhaust fan; 7 gallon gas bottles; automatic regulator; deluxe central control panel; bedroom wall comfort cover; bedspreads; 12v outlets; astrodome vent; sink covers with cutting boards; deluxe carpet; deluxe hubcaps.
The catalog states that you could also buy a standard Land Yacht grade trailer, and purchase one or more of these International features as "options." This might explain why a trailer has some of these features, but not all.
04-07-2005, 10:49 AM
#20
1956 22' Safari
Conifer/Evergreen
, Colorado
I've moved this thread because I orginally posted it in the '64 GlobeTrotter section and it really applies to a broader spectrum of vintage trailers.
Shari
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Blinds for my 1964 Safari
Neenm |
Upholstery, Blinds, Walls & Interior Finishes |
19 |
09-18-2003 04:33 PM |
