Go Back   Airstream Forums > Airstream Community Forums > Airstream Classifieds
Click Here to Login
Old 01-16-2023, 01:37 PM   #1
1995 34' Limited
Loveland , Colorado
1995 Airstream Classic 34 - Colorado
1995 Airstream Classic 34' Wide Body. Perfect for your next winter/spring project! All the furniture in this coach has been removed, and stored, with the entire interior body having been updated and restored! This trailer is ready for you to reinstall the previous furnishings or create the interior of your dreams with half the work already done for you!
A complete list is available below of the partial restoration that s been completed:
This coach has had all of the interior furniture photographed and removed. Interior pieces were retained as templates for new design, but can be used at buyer s discretion.
Entirety of interior aluminum skins and the old insulation was removed. All new Prodex Total Closed Cell R18 placed against the outer skin, 1 inch of pink insulation and a second layer of Prodex placed inside the frame before skins were replaced. For a total of R40 throughout the coach.
All new trailer vehicle lighting installed with easy access fuses.
All exterior lights were replaced with LED, new running lights, turn signal lights, and brake lights and switched to a fuse panel.
AC electrical system upgraded to 50 amp.
New 50 amp Service panel added. Pre wired for Inverter connection from batteries to AC panel. Inverter is included.
All new AC electrical wiring installed throughout the coach with full service outlets. All new battery system, DC electrical wire installed w/ HDMI run throughout as well.
Battery cages for up to 4 deep cycle batteries. Batteries are not included.
2 50 amp battery chargers are INCLUDED.
New DC wiring system fuse panel for easy access. Pre wired for DC lighting and switches throughout the entirety of the coach.
Main room and hallway lights upgraded to multi colored and bright white LED dimmable with wireless controllers included App available on Play Store.
4 120 watt Flexible Solar panels installed and wired to the battery bank with reverse charge diodes ready for batteries. This is a great dry camping unit!!
4 Rear facing digital cameras added for easy viewing.
New rubber roof installed approximately 5 years ago. This coach had an original rubber coating that was failing and was removed and replaced. With solar panels installed at this time. Coach has been stored under a canopy since this time.
New propane plumbing with 2 40 Lb. horizontal tanks under a fully customized tongue cover. Tanks were recertified in 2018 and are full!
Includes upgraded range brand new , range hood, and refrigerator used 6 months . Refrigerator is triple powered with exhaust that has been pre wired with thermostat sensor controlled fans to use as little power as possible.
Upgraded furnace, new AC, and new fans in roof.
New 3/4 marine grade plywood floor throughout the coach
2 New double pane skylights have been installed with smoky glass to prevent overheating and interior damage.
Customized cages have been made to cover wheel wells to prevent destruction of wiring and plumbing in the instance of an accident or tire blowout.
12V Electric Jack
5 Manual awnings
This coach has most of its original furniture, hardwood oak cabinetry, and window frames present. Window frames can still be purchased online as well as some are discolored from age. Exterior of coach is dent free and ready for polishing.
One exterior window rock guard is missing, but can be purchased online.
All 6 tires need to be replaced on this triple axle coach. They have good tread but are not legal as they are as old as the coach. Class E will be required if requesting transport. For purchasing reference, size is 255/75/R15
This stunner of an Airstream would be a perfect fit for a plethora of uses! Use to live in, vacation from, Air BnB it, use as an event vendor, restaurant, or whatever you can dream up!! This is a RARE find with this much time invested w/ an empty palette to start with!
1,000 s more photos of original state and restoration process are available upon request. Seller is willing to deliver with fees. Located in Weldona, Colorado
View this ad at Airstream Classifieds - 1995 Airstream Classic 34 - Colorado
nococonsigns is offline   Reply With Quote
1995 Airstream Limited 34 - Colorado bqualityauto Airstream Classifieds 0 10-24-2014 04:44 PM
1995 Airstream Excella 28 - Colorado MrChips Airstream Classifieds 0 08-31-2014 03:53 PM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
1995 Airstream Classic Cummings Diesel Pusher Motorhome eBay Watch Airstreams on eBay 0 06-29-2010 10:20 PM
