Meet our gorgeous Airstream in excellent condition with tons of storage!
This absolutely beautiful 2007 23 Safari Special Edition 75th Anniversary;
Relax under panoramic windows and an interior that is beautiful and classic. The recessed lighting, and polished aluminum walls make this amazing Airstream seem more like a modern art sculpture than an RV. If you are looking for a great travel trailer that will serve your needs, look no further. Nothing beats the quality craftsmanship of an Airstream. Everything works great and it is ready to hit the road!
New upgrades May 2021;
Smart TV, Waterproof flooring ,4 tires , 2 new batteries
Factory specs on the 2007 Safari 23 model, taken directly from Airstream literature:Sleeping area: Corner double bed measures 77 x 50 and the living room sofa also folds into a double bed.
UVW empty weight : 4460 pounds GVWR: 6,000 pounds NCC Net Carrying Capacity : 925 pounds Styled aluminum Wheels Radial Wall Tires Load Range D 10 Electric Drum Brakes Manual Hitch Jack 4 Stabilizer Jacks Spare Tire Bracket Double Steel Step.
Appliances: 11,500 A/C w/Heat Strip amp; Manual Control 18,000 BTU Furnace w/Electronic Ignition 3 Burner Cooktop w/Over Range Hood w/Vent amp; Light 2 Ceiling Vents Bath Exhaust Fan
12 Volt 5.0 Cu. Ft. 2 Way Refrigerator Probeless Tank Monitoring System Wall Mounted 6 Gallon Water Heater w/Electronic Ignition Shower Head w/Shut Off Water Heater By Pass Kit Lockable Water Fill Water Pressure Regulator Toilet 30 Gallon Fresh Water Tank w/Drain Valve 18 Gallon Black Water Tank 21 Gallon Grey Water Tank.
Specifications: Exterior Height w/AC 9 5 Interior Height w/AC 6 5 Exterior width 8 Interior Width 7 7 Exterior Length 23 Hitch Ball Height 17 3/4 Safety Chain Hook 11,700 Rating Sewer Hose Storage Tube Heated Tanks
12 Volt
It breaks our hearts to sell this beauty, but it will be a gem for the next owner!
pick up is in Downey, CA.
20 min from downtown Los Angeles.
Serious buyers please no haggling.
View this ad at Airstream Classifieds -
2007 Airstream Safari SE 23 - California
