We are sad to let our American Walkabout home go, but are starting a new journey.
200 Watt Solar, Airstream Connect, and E 4 Weight Distribution Hitch.
Purchased at Southland RV.
Comes with just about everything you ll need.
Everything works great!
Smoke Free
Completed Yearly Maintenance: 9 14 2020 at Airstream of Tampa
There is a small scratch on the exterior near the door from the previous owner photo attached . We also encountered some very minor hail damage while traveling, but it s only noticeable in certain lighting or if you re truly staring hard photo attached .
Full Propane Tanks
Propane Sensors 1 will need to buy 1 for second tank works with Mopeka Tank app for readings
Professionally Installed Skirt that fits to the Airstream and is removed easily from Sharp Tarps in Utah 2,500 value
Air Pressure Sensor in Tires that you can sync app to view while driving
X Chocks
Leveling Blocks
Camco Heated Hose
Black Tank Hose optional
Fresh Water Hose
30 Amp Power Cable
50 Amp Connector Dog Bone
Netted Hose Bags Electrical, Fresh, and Sanitary
Installed Removable Curtains, but left room dividers as well.
2 Portable Humidifiers
1 Portable Air Cooler
Govee WiFi Temperature Humidity Monitor w/App Alerts
All Original Airstream Pillows
2 Vent Insulator Pillows w/Pillow Case Covers
Custom sized Reflectix Insulation for every window
SIM cards for Airstream Connect are not included due to personal account/billing, but can purchase with AT amp;T. There is a secondary slot to have another carrier. We used RV 4G which is unlimited T Mobile.
WiFi Camp Pro 2 Repeater helps boost the campgrounds wifi signal making it easier to stay connected.
All Manuals
View this ad at Airstream Classifieds -
2018 Airstream Flying Cloud 25 - Colorado
