PRICE DROP
Pulled this 1000 watt inverter from a 2021 Airstream I did a solar upgrade on. It is in NEW unused condition.
1,000 watt inverter lets you use appliances and devices wherever the road takes you. Pure sine wave technology is perfect for sensitive electronics like HDTVs and computers. Built in automatic transfer switch changes to shore power when available.
Features:
- 1,000 Watt inverter provides AC power for electronics and appliances inside your RV
- Pure sine wave technology replicates household AC power, allowing you to run devices safely
- Perfect for sensitive electronics like HDTVs and computers
- Integrated transfer switch automatically changes from inverter to shore power when you hook up at the campground
- Fixed mount remote lets you control and monitor the inverter
- Multiple connection points let you secure cables and external devices to the inverter
- Includes AC input and output terminals, DC input terminals, and remote port
- Built in safety features protect your RV's electrical system
- UL listed
- Made in the USA
Specs:
- Application: 12V battery systems
- Rated power:
- Running rated power output: 1,000 watts
- Starting surge power output: 2,000 watts
- Voltage:
- Input: 12 VDC
- Output: 120 VAC
- Transfer switch power: 15 amps
- Maximum wire gauge: 1/0 AWG
- Cable length: 25'
- Dimensions:
- Inverter: 11 5/8" long x 10 5/8" wide x 4" tall
- Remote: 4" wide x 2 3/4" long x 1" deep
- Weight: 7 lbs
View this ad at Airstream Classifieds -
Progressive Dynamics 1000watt inverter - Alabama
