Go Back   Airstream Forums > Airstream Community Forums > Airstream Classifieds
Click Here to Login
Old 09-02-2020, 04:43 PM   #1
Los Angeles , California
2011 Airstream Flying Cloud - California
In Great Condition.
[table]<colgroup><col /><col /></colgroup>[tr]<th>Exterior Length</th> <th>27 ft. 11 in.</th> [/tr][tr][td]Exterior Width[/td] [td]8 ft. 5.5 in.[/td] [/tr][tr][td]Interior Width[/td] [td]8 ft. 1 in.[/td] [/tr][tr][td]Exterior Height with A/C[/td] [td]9 ft. 9 in.[/td] [/tr][tr][td]Interior Height with A/C[/td] [td]6 ft. 7.5 in.[/td] [/tr][tr][td]Maximum Trailer Capacity GVWR lbs. [/td] [td]7,600[/td] [/tr][tr][td]Net Carrying Capacity lbs. [/td] [td]1,621[/td] [/tr][tr][td]Fresh Water Tank gal. [/td] [td]37[/td] [/tr][tr][td]Gray Water Tank gal. [/td] [td]34[/td] [/tr][tr][td]Black Water Tank gal. [/td] [td]34[/td] [/tr][tr][td]Refrigerator[/td] [td]2 way 7 cu. ft.[/td] [/tr][tr][td]Oven LP Gas [/td] [td]STD[/td] [/tr][tr][td]Sleeping Capacity[/td] [td]Up to 6[/td] [/tr][tr][td]Ducted Furnace BTU [/td] [td]30,000[/td] [/tr][tr][td]Convection Microwave Oven Replaces Oven [/td] [td]OPT [/td] [/tr][tr][td]Convertible Dinette, Lounge and Bed[/td] [td]42 x 76 [/td] [/tr][tr][td]Hitch Weight with LP amp; Batteries [/td] [td]899[/td] [/tr][tr][td]Unit Base Weight with LP amp; Batteries [/td] [td]5,979[/td] [/tr][tr][td]Interior Windows amp; Skylights[/td] [td]19[/td] [/tr][tr][td]Master Bed Configurations[/td] [td]Queen 60 x 75 [/td] [/tr][tr][td]30 AMP Service Single A/C with Heat Pump BTU [/td] [td]15,000[/td] [/tr][/table][table]<colgroup><col /></colgroup>[tr]<th>4 Manual Heavy Duty Stabilizer Jacks</th> [/tr][tr][td]Airstream Custom Aluminum Entry Step[/td] [/tr][tr][td]Aluminum Entry Door Handle[/td] [/tr][tr][td]Aluminum Removable LP Cover[/td] [/tr][tr][td]Black Tank Flush System[/td] [/tr][tr][td]Cable TV Hookup[/td] [/tr][tr][td]Cast Aluminum Door Hinges[/td] [/tr][tr][td]Cast Aluminum LED Tail Lights[/td] [/tr][tr][td]City Water Inlet with Water Pressure Regulator[/td] [/tr][tr][td]Custom Aluminum Handcrafted 26 in. Wide Entry Door with Window[/td] [/tr][tr][td]Dedicated Waste Hose Storage[/td] [/tr][tr][td]Enclosed Aluminum Insulated Heated Underbelly[/td] [/tr][tr][td]Exterior LP Gas Low Pressure Grill Connection[/td] [/tr][tr][td]Exterior Shower with Hot amp; Cold Water[/td] [/tr][tr][td]Fluorocarbon Treated UV Protected Aluminum Exterior[/td] [/tr][tr][td]Goodyear Endurance ST225/75R15 Tires, Balanced[/td] [/tr][tr][td]Hand Painted Chassis[/td] [/tr][tr][td]Handcrafted Welded Extruded Aluminum Window Frames[/td] [/tr][tr][td]LED Dimmable Patio Awning Light[/td] [/tr][tr][td]LED Entrance Light[/td] [/tr][tr][td]LED Storage Compartment Light[/td] [/tr][tr][td]LED Tank Service Light[/td] [/tr][tr][td]License Plate Bracket with LED Light[/td] [/tr][tr][td]Lockable Fresh Water Tank Inlet[/td] [/tr][tr][td]LP 2 30 lb. Steel Tanks with Auto 2 stage Regulator[/td] [/tr][tr][td]Manual ZipDee Patio Awning with Sunbrella Fabric[/td] [/tr][tr][td]Nev R Adjust Brakes[/td] [/tr][tr][td]Nev R Lube Sealed Bearings[/td] [/tr][tr][td]Polished Bumper with Storage[/td] [/tr][tr][td]Powered Hitch Jack with Light[/td] [/tr][tr][td]Rear View Monitoring System[/td] [/tr][tr][td]Satellite TV Hookup[/td] [/tr][tr][td]Seamless Composite Flooring[/td] [/tr][tr][td]Semi Monocoque Aluminum Superstructure[/td] [/tr][tr][td]Shock Absorber[/td] [/tr][tr][td]Solar Front Window Protection[/td] [/tr][tr][td]Solar Pre wire Rooftop amp; Front Access Points [/td] [/tr][tr][td]Spare Tire Full Size[/td] [/tr][tr][td]Stainless Steel Front Stone Guard Protection[/td] [/tr][tr][td]Stylized Aluminum Wheels[/td] [/tr][tr][td]Temperature Reducing One Piece White Aluminum Roof[/td] [/tr][tr][td]Tempered Tinted Windows with Double Cam Latching System[/td] [/tr][tr][td]Thermal Barrier Protection Between Interior and Exterior[/td] [/tr][tr][td]Torsion Axle Suspension[/td] [/tr][tr][td]Unique Front Door Key with Heavy Duty Deadbolt[/td] [/tr][/table]
View this ad at Airstream Classifieds - 2011 Airstream Flying Cloud - California
Georich12 is offline   Reply With Quote
2011 Airstream Flying Cloud 25 - California Jpschafer Airstream Classifieds 1 07-31-2014 05:05 PM
2011 Airstream Flying Cloud 25 - California raguemoe Airstream Classifieds 0 01-15-2014 11:34 PM
2011 Airstream 20 FLYING CLOUD 2011 eBay Watch Airstreams on eBay 0 01-21-2011 06:20 AM
