01-25-2005, 06:25 PM
#1
Austin
Tradewind Rockguard Installation
I have a new rock guard sitting in my garage waiting to be installed on our '71 Tradewind. Our trailer apparently had a rock guard installed at one point - guessing from the aluminum extrusion above the window and the hold-downs below (hopefully the photos will post....).
So, the questions for you folks who have done this install before...
I assume the old extrusion above the window needs to be removed (the upper curl with the unshaven rivet)?
How/where did you position your rock guard vertically?
Finally, any recommendations on how to remove the old latches since they don't look like they will work with the new guard?
Thanks!
- Mark
Austin, TX
01-26-2005, 10:29 AM
#2
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Rock Shield
I installed one on my '75 Trade Wind last fall. It went on with out a hitch. Just had to level it up and screw (and seal) it above the front window.
http://home.comcast.net/~balrgn/Airstream/DSC02279.jpg
http://home.comcast.net/~balrgn/Airstream/DSC02280.jpg
I did have to do some hand bending to get it to the shape of the front. It was off a bit. I did not have to remove any former hold downs as one was not previously installed.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
2007 GMC Sierra 2500 HD Duramax
WBCCI 1754 - AIR # 6281
www.balrgn.com
01-26-2005, 02:48 PM
#3
1976 27' Overlander
St James City
, Florida
balrgn, Just wondering where you purchased your guard and what kinda money it was?
01-26-2005, 03:54 PM
#4
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
I'll send ya a PM with details.
www.balrgn.com
01-26-2005, 09:00 PM
#5
Me Too!
Balrgn,
I would like to have some details too!!
Perhaps others would as well...
So a PM would be fine, or just post here.
TIA.
Sav'h Steve
01-27-2005, 12:29 AM
#6
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
, California
Me too, me too please....
01-27-2005, 10:27 AM
#7
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
I located a dealer not too far from me,
AIRSTREAM OF NEW HAMPSHIRE
717 Rt. 101 A
Merrimack
NH, 03054
United States
Telephone 603-579-0700
Or their new parts dept.
Steve 603-673-3333
I got in touch with Vern for a price quote, he came in at or lower than 3 other quotes that I got. Also, I asked to have it drop shipped to my address. It came in UPS. The box had some damage to it, nothing serious.
I installed it by myself, so it wasn't too tough. I lined it up with the center section of the window, drilled and screwed in the center fastener. From there I found that the shape did not conform to the shape of the Airstream. I removed it and worked the shape back into it as best I could with out it being mounted. (It bends real easy) I mounted it back on and installed the farthest right and left fasteners (Screws that came with it) After a few more tweaks to get it to the propper shape I installed that reaining fasteners.
The cost was around $400, I’d have to look to see if that included shipping?
www.balrgn.com
01-27-2005, 10:52 AM
#8
1960 28' Ambassador
Northern
, California
Thanks for the info.
Do you have any pictures of the actual mounting and hardware used?
Thanks!
01-27-2005, 11:27 AM
#9
Corona
, California
Rock guard
You can see that rockguard and hold down hardware on our web site.
inlandrv.com
Click on parts and scroll to part # 34943.
Click on "view part" tp see it.
Perhaps that will answer your questions.
01-27-2005, 01:55 PM
#10
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Thanks!
It's a bit frozen out there, does this pic help?
www.balrgn.com
01-27-2005, 02:27 PM
#11
1960 28' Ambassador
Northern
, California
Being in CA I didn't realize it was too cold to go outside! ;-)
Thanks for the picture.
02-17-2005, 02:00 PM
#12
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Finally got the AS into a garage to work on the exterior. Here is the pic I promised to show the hold down of the Rock Shield. I did not get instructions with mine when I unpacked, SO I saw a Bambi nearby and stopped to see how they had mounted the hardware
www.balrgn.com
02-17-2005, 02:39 PM
#13
vancouver
, Washington
A word of advice.
Once I had Armor All protected the rubber, mine would NEVER stay in the little metal indents, they were too slippery (protected I guess)
I now use small wire ties to hold the rubber tabs to the metal rest and cut them each time I want to open the guard.
The wire ties certainly keep the guard closed securely
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
02-17-2005, 02:41 PM
#14
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Ooooo Good point, I'll remember that! SOmetimes I can't help myself spiffing things up!
www.balrgn.com
02-21-2005, 05:47 PM
#15
Austin
Don, I owe you one!
Don (Gunnyusmc) offered to give me a hand yesterday...
In 4 and a half hours (including lunch!) we installed my rockguard and two axles.
The rockguard installation made a lot more sense once I received the hardware kit! When I first posted all I had was the rockguard itself. Thanks to balrgn for the photo showing the hold downs and other pointers.
The axles were easy once we figured out right from left and which end of the shock mounts where. Just jack them up and bolt them down. Had to jack up the trailer quite a bit higher to remount the wheels.
Don, call me when you are ready to install your awning.
(First photo is Don drilling out old rivets.)
02-21-2005, 07:25 PM
#16
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Nice job! Hey, too funny I just installed the level you have on mine!
www.balrgn.com
02-22-2005, 07:26 AM
#17
Austin
Levelheaded
The level came handy. We slid the level lower so the rockguard would clear it. Then we were able to use it as a support while we positioned the rockguard left to right.
- Mark
08-01-2007, 11:02 PM
#18
We are just about to install this same rockguard on our '75 Safari. Just finished removing and cleaning behind the Zip-Dee that was there for 20+ years.
Could anyone elaborate on where exactly the brackets should attach? (The ones that prop the rockguard open as an awning).
