-   -   Just got a gutted '69 Sovereign any words of warning? (https://www.airforums.com/forums/f36/just-got-a-gutted-69-sovereign-any-words-of-warning-99275.html)
DToKage 12-07-2012 12:06 PM
4 Attachment(s)
I just bought a 31 foot 69' Sovereign land yacht it was rebuilt from salvage and didn't come with any of the original interior. I've been reading through the forums trying to figure out what my first step would be and was wondering if anyone had any words of warning or things to look out for.
The first thing I want to do is take down the interior walls and ceiling there's a bunch of little screw holes and other gaps in the interior "skin" so I was thinking I need to replace it all.. I've seen from other rebuilds where people take thin pieces of wood (marine board?) to line the inside. Are there any serious considerations with doing this? I know I'm going to need to strip it down to the frame and outer shell to reseal the outer shell. Is there an affordable compound to do this? also the insulation is in pretty rough shape so I was kinda thinking I'd have to replace most if not all of it. I'd rather not use fibreglass if there was another option.. I've heard of people using spray in foam but I have no idea how to go about doing that.
After that I know I'll probably need to pull up the floor and address any frame issues.. I'd rather not do a fram-off if I can avoid it for the simple fact of I don't know if I have the tools to pull it off. is there any serious concern to address before I start pulling up the sub floor? my plan now would be to pull it up in sections so that I can trace out the right shape on the new boards. The sub floor generally consists of something like 5/8" OSB board, some kind of insulation barrier and another layer of like 1/4 inch plywood right?. I would also like to coat the frame in some sort of rust-protectant. I also need to attach some outriggers, would that be best to do while the floor is out?
Also I haven't been able to find if there's some sort of needed-tool list. I'd like to get something to polish the skin and I know I'll need some kind of rivet gun.. is there a suggested tool list somewhere?
I guess all I'm trying to end up with right now is a sound, clean, water sealed trailer with a solid floor, I'll worry about putting in any shelves or whatnot after that.
Sorry for the wall of text, thank you.
DToKage 12-07-2012 12:19 PM
Here's a better picture showing the inside, I'm thinking that under that plywood in the back it's looking like there could be some water damage.. any serious concern there?
Inland RV Center, In 12-07-2012 02:44 PM
In spite of living in Arizona, the first major project should always making the coah "weatherproof".
Then make a list with time and costs of everything you want to do to it.
With that list, you can better plan your time and expenses for the parts.
azflycaster 12-07-2012 05:13 PM
The sub floor should be a single layer of plywood which attaches directly to the frame. The extra ply in the rear is covering something. There should have been a bathroom there at one time.
