-   Steps (https://www.airforums.com/forums/f475/)
-   -   Quickee step problem (https://www.airforums.com/forums/f475/quickee-step-problem-96040.html)
prayerwheel 09-04-2012 12:20 PM
Hi, I have a 1992 300LE and I replaced the Quickee steps a couple years ago, and they have worked fine since then till my last trip. I have checked the elec current at the plug connector, and found that the white wire is not getting power. The diagram for the wiring says that there is a fuse in the white wire line somewhere. Does anyone have any idea where this fuse might be? I have looked al over, checked all the fuses and breakers that I know of and no luck. Thanks for any thoughts. Tom G:)
