-   All Argosy Trailers (https://www.airforums.com/forums/f227/)
-   -   sewage dump hose (https://www.airforums.com/forums/f227/sewage-dump-hose-93087.html)
oldiesel 06-29-2012 01:06 PM
sewage dump hose
On our recently purchased 1978 24ft Argosy the pipe that the dump hose fits on is a different size (larger) than on previous sobs :eek:
Is there an adaptor that will fit what seems to be the standard hose and connect to the existing dump pipe on the Argosy,if so where might i find one?
TIA Don
Foiled Again 06-29-2012 01:45 PM
New trailers use Valterra fittings. The older ones used Thetford - slightly larger. Vintage Trailer Supply may have Valterra/Thetford adaptors. All the modern hoses you buy have the Valterra type fittings. Just put the adaptor on the outlet valve of the trailer.
Paula
Silver Otter 06-29-2012 02:03 PM
Yep, as Paula said:
Valterra T05-2285VP Thetford to Valterra Universal Adapter
I carry an extra just in case.
ROBERT CROSS 06-29-2012 02:08 PM
<My dumb mistake....fix
Don,
On our last trip I lost the OEM dumper cap....my bad, not secured properly. :sad:
This ended up being the 2hr Camping World on the road fix.
After insisting that the covers they had would fit, they didn't, we tried them all. I showed them that the spare end of a dump extension hose I had did fit. (the adaptor that FA mentioned, the white part in the photo) The the blue cap they had in stock fit tightly over that, I used Marine-Tex to bond them together.
Look for a hose adaptor that has just two "hooks" as opposed to the AS's four, that is the only style that will fit ours.
Hope this helps, :wally:
:blink:
oldiesel 06-29-2012 04:35 PM
:D Thank you all. This has got to be one of the best information resources on the internet,Quick replies with the real answers.
Boy am i glad i found this group
