Zamp panels are not the cheapest choice. Victron 2000 watt inverter is $1155.00. ( the 3000 watt is only a few dollars more at $1284.00) Victron 100/50 $323.00 Victron 712. $226.00 Lifeline $376.00 ea Zamp 100 watt. $899.00 a pair. (RENOGY ECLIPSE $187.00 each) $5500.00 is right on the equipment. (Renogy Panels would save you Some) As far as labor 100.00 to 135.00 is about right. I might would do it for a little better rate but it’s still a big job and 40-50 hours is in line with how long it would take. I would budget a week. If you would drive up from FL and be willing to help we should talk. Being part of the install is a great way to learn the system. |
Solar Install Costs...$8k
8 Attachment(s)
^^^^ X2. You get what you pay for if you have the very best pro install the very best equipment, all done the right way without compromise. Lew did my install and I couldn’t be happier to this day. Just a few odds and ends and such... couple batteries, a solar panel or two, a charge controller, easy / quick DIY right? I think not. Worth every penny and I got 30% back in tax credits. 800watts of solar - Eight AM Solar SP100 panels up top. Ability to tilt if needed Victron 150/85 MPPT controller (Smart w/BT) Victron 12/3000 Multi-Plus inverter/charger with 50A pass-though * PowerControl (ability to deal with limited generator or shore power) * PowerAssist (ability to dynamically supplement the capacity of shore or generator power with batts) * Real-time uninterrupted 120v power supply when disconnecting shore / genset power sources Victron Lithium batteries (600ah total - 2 X 300ah batts) Victron CCGX monitoring panel with wi-fi and automatic upload to VRM portal Victron BMV-712 battery monitor (Smart w/BT) Victron Digital Control Center and BMV monitoring panel Victron BMS Victron Battery Protects (2) Victron Lynx 1000 distributor Victron component networking via VE.Bus and VE.Direct communication buses. WiFi / Internet uplink to Victron VRM portal via CCGX AM Solar AMS control module for cold weather and other automatic system disconnects Inverter, battery, solar disconnects for manual manipulation / inclusion / exclusion of components from the system, New 120v panel and sub panels New 12v panel Miles of heavy gauge cabling, fasteners, heat shrink, disconnect switches, etc WeBoost 50db LTE/4G/3G signal booster with Surecall external antenna and large internal panel antenna mounted mid-ship for re-broadcasting through the trailer. |
