-   -   Frame/B-wrap parts (https://www.airforums.com/forums/f36/frame-b-wrap-parts-92451.html)
ehodg66 06-13-2012 02:31 PM
Frame/B-wrap parts
Hello all. I've just removed my front banana wraps on my quest to frame and floor restoration. These trim parts i just removed where the frame meets the B-wrap , and being they are 40 years old, where quite brittle and one partially disintegrated.
Can I get these at Inland RV or another supplier or is someone substituting something else.
thank you
Eric
Lance M 06-17-2012 07:56 AM
Eric,
Those plastic trim pieces are no longer available. You can fabricate them out of sheet aluminum.
ehodg66 06-17-2012 08:10 AM
Thanks Lance,
I have not seen any posts on these or The fabrication of them. I had a feeling they were hard to come buy. It's ashame no one has made a mold of these. Maybe some kind of hard rubber that can form to the shape a little easier than aluminum. Thanks again Lance!
Eric
wahoonc 06-17-2012 08:42 AM
Mine are toast too.
I am going to be fabricating some out of a high temperature PVC roofing material, probably the flashing grade 60 mil. I am still quite a ways out, but will try to remember to post the results.
Aaron :cool:
Inland RV Center, In 06-17-2012 09:45 AM
thank you
Eric
The original have been gone for many years.
A small section of aluminum works just fine, especially when you seal the edges with Vulkem.
ehodg66 06-17-2012 11:16 AM
Thanks Aaron, looking forward to your posts.
Thanks Andy, All things end in Vulkem :)
scottaandy 06-17-2012 04:19 PM
I'm about to pull my 1975 GT banana wraps, also for a shell off floor replacement. Here is a product - Sugru might be used to repair or fashion new seal trim where the tongue meets with the b-wrap. Sugru (sugru.com) is a moldeble silicon rubber. I have not used it - yet, but I can see sugru becoming an indispensable repair item as long as I own an AS.
