-   -   1964 Tradewind Awning (https://www.airforums.com/forums/f442/1964-tradewind-awning-92446.html)
KnightAir 06-13-2012 12:44 PM
I recently purchased a 1964 Tradewind. Curious how long of an awning to put on curb side. I know ZipDee is typically what goes on Airstreams, is that correct.
InsideOut 06-13-2012 01:10 PM
On vintage trailers, another alternative to an expensive ZipDee is a rope & pole awning. They are much less expensive and keep in character with the old-time vintage feel. There are two readily available options - Vintage Trailer Supply & Marti's Awnings.
Either way, the awning typically goes the full width of the flat panel. There should be an awning rail on your trailer already - it's the little c-shaped channel that you feed a rope or rod trough. If you are going the rope & pole route, just measure the length of that. If going with a ZipDee, I would have the dealer you order it from measure it for you.
Shari :flowers:
