Foiled Again |
06-09-2012 03:56 PM |
Originally Posted by ROBERTSUNRUS
(Post 1158619)
:) Hi, Note: that the store function is by-passed, [red light on] and you cannot turn it off, while plugged into shore power. But it will return to whatever position it was in, [off/on] after you disconnect your shore power cord.
Thank you - I forgot about that! While you're plugged in, it's charging and you can't put it into "store". While traveling I don't think the lights will work unless you've got it "ON".
Another little note, you'll hear a fan running on the converter and it will put out heat even with the AC on. About once a month you should turn the converter off, and vacuum out the fan. It won't run constantly unless the filter is starting to get plugged. Mine is under the bed, so I just lift the bed and the fan is visible from the top. Quick little wand job and I'm done.
OH - RESETTING the breakers, you can pop a breaker and it looks like it's OFF, then it won't reset. It's not off, it's OPEN. Push down on the breaker and it will turn all the way OFF, then pull up and turn it back ON. There are also fuses on the converter. Buy spares. They never fail until you're boondocking 50 miles from nowhere and it's 3:00 AM.
Happy Trails, Paula
