-   -   '72 Tradewind frame question (https://www.airforums.com/forums/f36/72-tradewind-frame-question-91824.html)
ehodg66 05-29-2012 08:42 AM
4 Attachment(s)
I purchased my 72 gutted and the PO had already replaced 2 main pieces of the frame running out to the bumper. Apparently rusted from the rear bath. The belly pan was also partially eaten away as you can see in the pics.
My question is, did the PO neglect to add back any rear outriggers? I have not found any pics on the forum of a 72 bare frame for reference. Any pics, dimensions, drawings and advice would be appreciated. :)
p.s. i've added 2 pics of the PO welds. They look ok but the 2x2 sq tube he has for support from c-channel to c-channel doesn't look like enough support.
perryg114 05-29-2012 10:58 AM
Yes there should be some outriggers to support the shell. I would say there are two to three missing on each side.
Perry
68 TWind 05-29-2012 12:12 PM
On my 68 there are no outriggers past the last main frame crossmember. Yours look OK.
The floor is the only support in the curves in the rear.
Tom Nugler 05-29-2012 01:10 PM
Looks OK. I would have welded a plate across the lap joint in the channel, but thatís just me over-engineering things.
The wet bath wonít cause as big a load as a full one.
If you havenít already, search the treads on water intrusion through the joint at the bumper box cover and body into the floor.
Tom
perryg114 05-29-2012 01:24 PM
I would consider putting a plate across the welded area to add more strength to the welded area. This would be a plate that would be welded across the center section going from top to bottom. The PO should have made an angled cut where the old beam meets the new beam. It will fail first at the weld and rust first there as well. My 81 center bath Excella II has outriggers in the last 4 feet of floor. This may be a rear bedroom addition to the floor that they did not think was necessary with the rear bath where most of the floor is covered with bathroom fixtures. It may also be something that changed over time.
Perry
purman 05-29-2012 01:53 PM
I have a 1968 Ambassador 28'. From the rear axel to the back I have 3 out rig supports on either side. You might be missing some.
Tom Nugler 05-29-2012 02:19 PM
Here's copy of the chassis from my service manual. Might help a bit.
Tom
ehodg66 05-29-2012 04:24 PM
Thank you everyone for your input. I think I will take Toms advice and weld plates over the lap joints. Also, from the frame PDF supplied by Tom, it looks like I have all my outriggers but I need an added brace across the back directly under the shell. I'm sure i'll have more questions when I get the rest of my floor up.
Thanks again everyone!
