-   -   Overlander tail light housing (https://www.airforums.com/forums/f456/overlander-tail-light-housing-91333.html)
project66 05-18-2012 09:38 PM
I gutted a 66 Overlander Twin to replace the rear floor section and noticed signs of a water leak coming from one of the tail light area. Since the interior panels are off I drilled out the rivets and removed the housing to find no sealer of any kind between the body and the tail light housing. Is this a job for vulkem, silicone, or should there be a gasket of some sort? Any help would be appreciated.
Thanks, Tom
Inland RV Center, In 05-18-2012 09:41 PM
Thanks, Tom
Vulkem sealer.
