-   -   Cast Aluminum Reflector base for 1976 Sovereign (https://www.airforums.com/forums/f4/cast-aluminum-reflector-base-for-1976-sovereign-90867.html)
tommyp123 05-07-2012 08:26 PM
I need a lead to anyone who might supply a used or recreated cast aluminum base for the lower front reflector on a 1976 Sovereign. These are below the lower trim line and have amber lenses mounted on them. Some trailers have red ones in the rear as well. Thanks!
Wabbiteer 05-07-2012 11:42 PM
Would you mind posting a picture of the twin to the missing item?
Ganglin 05-08-2012 05:35 AM
TommyP - welcome to AirForums. Always good to see another OH member. Presume your talking about something similar to the reflector mount that was on the forward edge of the banana wrap. Out of Doors Mart has two showing on their web site for the rear but now sold out and NLA.
Light Base RS Rear sku376 Airstream Light Base [376] - $39.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
You might try Inlandrv.com and see if they have them - not showing on their web site that I see however.
Stoney 05-08-2012 05:41 AM
yes tommy inlandrv has them and out the door mart also has them dont know much i will check.
Stoney 05-08-2012 05:59 AM
Tommy I found them they are @ out the doors mart .com . Go to the parts page .Then airstream special go to the bottom of the page . They cost 39.95 each Light Base RS Rear sku376 Airstream Light Base [376] - $39.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Carolinda 11-14-2013 01:30 PM
As of November, 2013, this part is "no longer available" at Out-of-Door Mart, unfortunately. I'm very sad...
Silver Hawk 11-14-2013 06:07 PM
'Airstream Supply' has lots of used parts - if you don't see them on his web page, give him a call and he can usually has them of will find them for you. I've had very good luck with him.
