-   2005 - 2010 Safari (https://www.airforums.com/forums/f292/)
-   -   Bathroom Door (https://www.airforums.com/forums/f292/bathroom-door-90566.html)
mocus 04-30-2012 04:18 PM
Bathroom Door
Have19' Bambi 2006. Been working with it for quite a while preparing for first trip. Thought I had everything ready until an hour ago. My last testing was the hot water...worked great. Then...I had to replace one of the light bulbs over the stool. Went down and purchased correct bulb and went to replace it and the bathroom door is locked. I thought it might be like a door in the house that is easy to unlock. But, no, the handle will not move up or down; there is no place for any key, etc; cannot gently pry the door away from the latch........what in the world would make it lock automatically.....please help with this one. Many thanks, Tom
Goal15 04-30-2012 04:28 PM
Had same thing happen in our 2006 23 footer. Ours has a slight ind went in outside of lock that you can put a coin in to unlock it
Goal15 04-30-2012 04:30 PM
Make that a slight indent
mocus 04-30-2012 04:30 PM
Ya know, I noticed that on mine. I never thought trying a coin. I tried pushing something into it with nooooo luck. Will go out and try it now. Thanks
mocus 04-30-2012 04:38 PM
bathroom door
Darn, I can't stump anyone....That had to be one of the fastest posts/repair jobs on record. When I was trying to figure out what in the world happened, I noticed that slot and it appeared to me that a key should go in it. Nope. Oh, by the way, I used a quarter instead of a dime...I like to go first class. Thank you very much. Tom
Goal15 04-30-2012 04:44 PM
No problem. Always glad to pay it forward. My previous best for GETTING a solution was 16 minutes, so am glad to provide one in 10 minutes but even happier that it solved the issue
Dana
