-   Brakes & Brake Controllers (https://www.airforums.com/forums/f439/)
-   -   Just wanted to confirm 12/2 for a '78 Sovereign? (https://www.airforums.com/forums/f439/just-wanted-to-confirm-12-2-for-a-78-sovereign-90287.html)
Taylormade 04-24-2012 10:28 AM
I'm looking to replace my backing plates and wanted to ensure I got the right ones. This is what I'm checking out.
Any help/feedback would be greatly appreciated. Thanks!
Scott
Inland RV Center, In 04-24-2012 11:07 AM
Scott
Those are OK.
azflycaster 04-24-2012 11:40 AM
There is a different part number for the other side of the trailer.
Taylormade 04-24-2012 11:52 AM
Originally Posted by Inland RV Center, In (Post 1137983)
Those are OK.
Thanks Andy, when you say "ok", do you mean there's a better option for me or those will work just fine?
Yep, just need two per side, right? Nothing else I'm missing?
azflycaster 04-24-2012 11:55 AM
Since you are replacing thew backing plates, it would be a good time to repack the wheel bearings. I would add 4 grease seals and some grease to the list.
Taylormade 04-24-2012 01:10 PM
Yeah, actually the PO must have just had that done. That's how I found out I needed hardware kits for the brakes. The bearings and grease are new within 3 months.
Thanks!
Inland RV Center, In 04-25-2012 10:55 AM
Keep in mind, that the brake rating is only true when "everything" in the brake system, is perfectly adjusted.
You are looking at 5200 pound backing plates.
There are 6000 pound backing plates that are also available.
Then to go one step even better, you can get 6000 pound brake assemblies, "that are self adjusting". Those keep the brake system as close to perfect adjustment all the time, as you can get.
