-   -   '76 Sovereign - stolen, damaged, recovered: HELP! (https://www.airforums.com/forums/f36/76-sovereign-stolen-damaged-recovered-help-90052.html)
Dragonsleep 04-18-2012 10:53 AM
Hello friends
A fun project turned out to be very stressful when our yet-to-be-claimed Sovereign was stolen from its field last fall. It spent the winter with the door smashed open, and both door and screen were pummeled when the the ne'er do wells dragged our Sovereign through the Nova Scotian woods, to leave it, battered and wounded, mired in the back woods. The recovery is an amazing story (come by for a beer) but: we need an outside door and a screen door. Where do we start?
All suggestions, all locations, US or Canadian, are welcome.
The adventure begins.
Paul
Protagonist 04-18-2012 12:37 PM
Originally Posted by Dragonsleep (Post 1135334)
Hello friends
Paul
Since I own an Interstate class B and not a trailer, take this for what it's worth, which may not be much…
First question needs to be, are doors for Sovereigns interchageable with other models, or are they unique? The tech folks at Jackson Center could tell you that, as could other Sovereign owners here on the Airforums. If they are interchangeable with other Airstream trailers, your potential sources increase dramatically.
Next question to ask, are doors for different years interchangeable? Again, if you could use a door from a newer or older model, you have greatly increased chances of finding one.
Shacksman 04-18-2012 01:31 PM
Hello friends
Paul
If you still have the hinges and frame, the door can be reskinned far cheaper and easier then finding a new door. Even if the frame is broke it can be welded and then redone inside and out. I just did this with my Bambi door and it looks like new.
Skatiero 04-18-2012 01:40 PM
Doug has a good point! Your sovereign is a popular model and year, too, so you may be able t find a replacement if you want or need to go that route. There are rv salvage places out there like Colaws in MO.
overlander63 04-18-2012 04:40 PM
FYI, almost any main door from any 1974 to mid-1980's+ Airstream or Argosy trailer will fit. More will fit, but the newer doors have a squarer top edge, and I'm not 100% sure when the cutoff year is.
Aage 04-18-2012 06:10 PM
Howdy and welcome to Airforums.com Dragonsleep! You have come to the right place for answers to any questions. AS questions, that is! :D
While I agree that repairing the existing door would be the fastest and cheapest way to get the opening closed, a second choice could be a wrecker, such as Colaw RV (Google them).
I also would suggest contacting Can-Am RV in London, ON. I've been there a few times, and they appear to have a large number of older trailers parked in the back in the large field behind them. Contact Andrew Thomson (his member name here is Andrew T) and see if they have anything to sell you in the way of a door and screen door. Shipping to you from London should be considerably cheaper since you'll have no border to cross.
Good luck, and I hope they catch the )&^%r8@$%#s that did that to your TT!
Sodbust 04-18-2012 06:49 PM
What a bummer.. Good luck,, it always looks bad at the start of the repair..
Just take it as it comes and it might all fall together and be better than before..
Sodbust
