-   -   Frame Parts for 1963 Sovereign? (https://www.airforums.com/forums/f36/frame-parts-for-1963-sovereign-88761.html)
lunadog 03-15-2012 04:50 PM
We are just about ready to start frame repair on our "project" Airstream - a pretty rough 1963 Sovereign. The central beams seem ok but what I think are called the stringers or "joists" front and rear are very bad and will need replacing. I thought I saw somewhere a supplier for pre-cut steel stringers but can't find it now. Does anyone know where they might be available in bundles for Airstreams?
wasagachris 03-15-2012 05:45 PM
Inland RV lists both crossmembers(stringers as you call them) and outriggers for 1969 to 1993 units. I would call them to see if they will work or if they sell ones for your year trailer.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
Inland RV Center Inc.
marzboy 03-15-2012 06:18 PM
The crossmembers for the early to mid 60's are a bit different. Greg at Inland told me to use 2 2" steel angle. I actually had some custom bent out of mild steel, piece of cake. Those outriggers look pretty shot. I chopped them off mine and bought em from Inland. Yours might have to be cut down a bit. Nothing an angle grinder cant fix.
lunadog 03-18-2012 12:09 PM
Thanks for the info! I am going to start a new thread with more photos and of course more questions. We are using the search feature and learning so much.
marzboy 03-21-2012 09:18 PM
Ask away! I was in the same boat as you a year and a half ago. Your brain is gonna get so big youll need some new hats.
