-   -   Swapping the dinette for a sofa bed (https://www.airforums.com/forums/f7/swapping-the-dinette-for-a-sofa-bed-87216.html)
CMSmith 02-03-2012 07:07 AM
I am considering an Argosy that has twins in the center and a front dinette. Is there room for the dinette to be swapped out for a hide-a-bed sofa/love seat? I assume there is the width needed that something will fit, but what about popping out a bed towards the kitchen area? The one i am looking at at the moment (only online at this point) is a 24'. Thanks
Flynavy 02-03-2012 08:38 AM
I have all the parts you would need to make the switch. They were recently removed from my 25' Tradewind. I have the entire front lounge, cushions, radio, the whole setup.
CMSmith 02-07-2012 09:35 PM
what I am really looking to do is put in a more standard (home style) sleeper/sofa. Is this possible? Are there certain companies to look at for doing this sort of thing?
webspinner 02-07-2012 09:38 PM
Standard sleeper sofas are much, much heavier than the ones designed for travel trailers. Research what a conventional sleeper sofa would do to your tongue weight before you follow that route.
c_lewis77 02-07-2012 09:46 PM
Flexsteel makes RV couches
Try here - https://www.braddandhall.com/productc...p?idCategory=6
dkottum 02-07-2012 10:17 PM
Airstreams are at a smaller scale than homes, and most RV's. You could ruin the interior appearance with a too large sleeper/sofa, and rob it of it's precious space. Play it safe and use Airstream components.
doug k
cajunmast 02-26-2012 03:53 PM
can we have your dinette?
Would be very interested in purchasing the dinette from you... We have a '73 Argosy 28' and are wanting to remove our front gaucho and replace it with a dinette.
CMSmith 02-27-2012 06:34 AM
If we find the right Airstream for our family and end up pulling things out, we will certainly offer them up. Thanks
