-   Brakes & Brake Controllers (https://www.airforums.com/forums/f439/)
-   -   Do Henschen Axles Use Standard Backing Plates? (https://www.airforums.com/forums/f439/do-henschen-axles-use-standard-backing-plates-83345.html)
perryg114 10-05-2011 04:32 PM
I was wondering do Henschen axels use generic trailer brake parts and backing plates etc. or are they oddball?
Perry
wkerfoot 10-05-2011 04:44 PM
Generic.
Bill
Perry
overlander63 10-05-2011 05:46 PM
Perry
You can get them at any trailer or RV place. If you are replacing parts, you will need to know if you have round or oval magnets. The round were the old school stuff, the ovals are the modern stuff.
perryg114 10-05-2011 05:47 PM
Can you not upgrade to the ovals?
Perry
wkerfoot 10-05-2011 06:09 PM
If you purchase loaded backing plates, you will get the new oval magnets. Loaded backing plates is much cheaper than replacing parts.
Bill
Perry
Inland RV Center, In 10-05-2011 06:15 PM
Perry
The old style 12 inch electric brakes used round magnets.
The new style 12 inch electric brakes use oval magnets, that offer more stopping power.
Changing out the new backing plates for the old, has no drawbacks, as replacement is a piece of cake.
perryg114 10-06-2011 06:54 AM
What happens if you put an oval magnet in an old assembly?
Perry
Inland RV Center, In 10-06-2011 08:46 AM
Perry
DON'T.
You will regret it, besides the magnets cost almost as much as a backing plate.
perryg114 10-06-2011 10:07 AM
I assume the stock brakes are 12" diameter by 2" wide or 2-1/2" wide? I also assume that the bearings are generic as well.
Perry
Inland RV Center, In 10-06-2011 12:25 PM
Perry
The brake shoes are 12" x 2"
The inside bearing is 25580
The outside bearing, depending on the hub, was LM 67048 and is now 15123.
perryg114 10-06-2011 09:32 PM
Ok well I got the wheels off tonight. One of the 4 drums looks questionable. There is a pretty good sized groove in it. It may turn down ok but I think there will still be some groove left before it goes .090 over. So I may need a drum. The brakes shoes are shot on all 4 wheels. The bearings and spindels look ok. None of the bearings were siezed or stuck to the spindles. My axels seem to still have some flex left in them because the wheels dropped a good bit when I jacked it up. They have definately not solidified. I have not checked the bearings real close yet. I bet the drum is not going to be cheap if I can find one. I can put it back for this trip but I would prefer to have it working properly.
Perry
LI Pets 10-06-2011 09:43 PM
When these drums are turned do you need to turn the magnet contact area?
If so, I assume it takes certain type of equipment to cut???????
wkerfoot 10-06-2011 10:03 PM
What is your definition of cheap? They are generic and available at Camping World (not the cheapest place) or any trailer supply company.
Bill
Perry
Inland RV Center, In 10-06-2011 11:09 PM
A good machine shop can turn the drum brake surface and the "armature plate", the surface that the magnet rides on, as it must be smooth for best perfomance.
NevadaGeo 10-07-2011 02:22 AM
Perry, If you're changing drums, I'd recommend going to a disc.
Perry
(just had to do it)
perryg114 10-07-2011 03:38 AM
I have limited time to mess with this. I need to be on the road by Oct 16th. The magnet surface is good on all the drums I just need the brake surface cleaned up on one drum. One drum got down to the rivets. The magnet surface looks fine. Yes the magnet area could also be cleaned up but I have found most auto machinists are some kid who is not too bright. Many years ago I bought some new drums for an old van I was driving. They did not get the hubs pressed all the way into the drums and they turned my new brake drums to true them up with the hubs in crooked, talk about mad!!!!!!!!!!!!!!!!!!!!!
Perry
DGJackson 10-07-2011 05:21 AM
I'm in the middle of replacing axles and have old axles that are going to scrap yard. Old parts are priced at the you haul it off level.
overlander63 10-07-2011 06:27 AM
Perry
You can't, the parts are not interchangeable.
Perry
Stock is 12"x2".
perryg114 10-07-2011 08:29 AM
All 4 magnets are good. I had the wife turn them on while I held a screw driver to them.
Perry
perryg114 10-07-2011 08:44 PM
It looks like I am going to be able to salvage just about everything. I am having one drum turned and maybe some others depending on how they clean up. The bearings are all good and so are the seals. I was able to find shoes locally.
Perry
