-   Doors & Locks (https://www.airforums.com/forums/f453/)
-   -   Keyless Entry (https://www.airforums.com/forums/f453/keyless-entry-8270.html)
r doghse 12-08-2003 08:26 PM
Keyless Entry
Trying to locate keyless entry for 2004 30 landyatch,need price and if fairly mechanically inclined can it be installed without going to dealer,do instructions come with them.
Chas 12-09-2003 07:11 AM
Is that even available from the factory?
Sounds like it would be a tough job, maybe impossible. You would need sufficient room in the door to install a solenoid and a path to route the wiring. Motorhome doors and latches are different than car doors.
Maybe you could get one of those residential Kwikset punch locks mounted up to the door somehow? :D
Chas
thenewkid64 12-09-2003 10:30 AM
I think the new MH's already have an Electric solenoid on the deadbolt that can be actuated from a dash switch. I know I wish I had one. Just as I get settled in I see the light that tells me my deadbolt is not thrown and have to get up and flip it:p
87MH 12-09-2003 11:10 AM
I think the new MH's already have an Electric solenoid......
The '87 has the dash operated electric solenoid on the deadbolt, but it is not rigged up to operate from the outside.......
Probably wouldn't be hard to rig up though, wonder if a garage door type of receiver would carry enough amperage to activate the deadbolt.
The receiver would be a parasitic drain on the house batteries, though.....
donnall 12-09-2003 11:33 AM
My 93 Land Yacht Motorhome has a keyless entry with the key pad outside the door as well as a deadbolt switch on the dash. I'm not sure if it would fit your rig or not, but they do make such an animal. So you could ask Airstream about cost, fit, etc.
Don
thenewkid64 12-09-2003 01:20 PM
If the electrically activated deadbolt is already there then any car alarm or remote lock system sold at an auto parts store should work. All you need to do is find the wires and tap it in.
