-   -   1969 'C' Frame Channel is there a supplier (https://www.airforums.com/forums/f36/1969-c-frame-channel-is-there-a-supplier-82686.html)
Slowride66 09-18-2011 08:16 PM
Howdy Y'all!
I am In th middle of a rear bath fix on my 1969 Land Yacht & I was wondering is there a supplier that make the stuff I need?
I was thinking of cutting a slice off & taking it to the local welding / fabrication shop & see if they can make it for me but before I do I was looking for any & all advice on what to do & what not to do.
I wanna get this floor back in before it gets cold.
Yes Virginia it get cold here in Florida maybe I won't be shoveling snow but is did sprinkle a bit of that white stuff last year.
Thank You all very much!
SR66:D
PS pictures & stuff so far:brows:
https://www.airforums.com/forums/f36/...out-78002.html
https://www.airforums.com/forums/f443...his-82279.html
marzboy 09-20-2011 01:42 PM
You are talking about the floor channel correct? If so you can make it yourself if you have a sheet metal break.
Slowride66 09-21-2011 08:08 PM
The Frame Rails.
I took a slice to the local welding place & they said it was 11 gage metal & it would be about $100,00 for Two 8' pieces . that is as long as their break is.
SR66:D
marzboy 09-22-2011 09:18 AM
Ok gotcha. I believe my 65 was 12 ga cold roll. I had to fabricate some to repair the rear section of my trailer.
