Is there a good SMALL antenna?
I need to get an antenna for my Bambi II project, but the Winegard IV seems so huge for the little trailer top. Any suggestions for a smaller antenna with a good range? I saw the one that is a picture frame (pretty cool) but it only has a distance of 15 miles.
I have an indoor one I bought at walmart called a bat wing I put in my window and it picks up stations 60 miles away.
Jo |
Anyone else try an indoor antenna? There's not a whole lot of room inside a Bambi II, so I'm not sure if that's the route to go. It would be easy, though!
The antenna is just a piece of thin plastic .about 14" long.Doesn't take much room to store or to use.
Jo |
Laura |
RCA Digital Flat Antenna made for DTV.
Model# ANT1050XV https://www.walmart.com/cp/TV-Antennas/4536 Jo |
Have you seen the JACK off-air digital antennas yet?
Digital Over-the-Air HDTV Antenna The cool part is that if you buy the complete unit, it doesn't need to be retracted, as it's shorter when mounted...or you can buy just the antenna and install it on your existing 'crank-up' mast... I see the complete unit comes with a built-in digital signal strength meter so you can easily rotate the antenna for the best signal - great feature... I don't have one, so can't give a high-five, but it looks like a great new innovation in an RV Tv antenna!;) |
Somebody get one and report for us. :lol: |
I found this review from a guy who found it to be somewhat better in the same spot than his Winegard with the Wingman add-on. He also has a fairly detailed install description with quite a few pictures.
Since the PO removed my Argosy's antenna altogether to fix a leak, I'm starting from scratch and may give this a try. |
I'd love to hear if anyone has tried the Jack too. It would be nice to put one up & forget about it (I almost road off with my skyliner up one time!). Thanks all for the suggestions.
My friend installed the Jack on his Airstream and loves it. I finally purchased and installed one today.
INSTALLATION: It took me four hours ... but I'm slow it took most of my time getting the old unit off.. The only hangups I had was that the existing Wineguard hole was 1.5" and the Jack needed a 2" hole. It was tricky to keep the bit from walking, but I figured it out. Also, the footprint of the Jack is much smaller so I had to be generous with the Tremco. PERFORMANCE: I store my Airstream in a metal building. It was impossible to pick up any channels in the enclosure with my Wineguard. However, I picked up 6 channels with the Jack INDOORS. I suspect it will do substantially better once I get out into the great wide open. FWIW, my friend raves about the performance of his. APPEARANCE: Not sure I like the look. Looks like the half-dead, pale white E.T. Is riding on my roof. I'm happy with the result so far. |
Becky,
Please be sure to let us know of your experience with it? I'm thinking of getting one myself, for long-distance FM reception. |
Aage, Jack makes the same antenna in a model that attaches to the end of the traditional Wineguard apparatus. That version is a simpler installation solution if you have the real estate to spare on your roof. The one I installed is all plastic and will probably need replacing at some point.
Becky, before you go through the pains of installation, you might at least consider a possible exchange for the other version made by Jack. |
Ok then, I think you will be pleased with the Jack.
Thanks! |
Yes, it was fairly simple removing the old one. Remove screws and sealant. You may need a Dremel to knock the rivets off the stand that cradled the old antenna. The only tricky part to the install was increasing the diameter of the existing roof hole that the directional shaft goes through. Good luck!
