-   -   Solar is not charging my batteries. Help! (https://www.airforums.com/forums/f448/solar-is-not-charging-my-batteries-help-76649.html)
DaCosta 04-25-2011 08:01 PM
Hello everyone please I need so advice. I own a 22" international It has a solar package I cannot get the solar panels to charge my battery.
bryanl 04-25-2011 09:36 PM
Trace it out.
There should be a wire from the solar panel to the charge controller and voltage on that line should be 18v or better in full sun. There should be a wire from the charge controller to the battery and that should read 13 to 14 volts or so without the battery connected. With the battery connected, you should be able to get some current going from the charge controller to the battery.
